Window off track how do I take off door panel?
If you want to take off your door panel:
1) Pop out your door courtesy light. Unscrew and disconnect.
2) Door handle, unscrew.
3) Door lock, use a flathead and pry out towards the back. The handle that you pull does NOT come off with the assembly. Just pry around the edges carefully.
4) Two screws on the bottom, unscrew.
5) Now the hard part: Pull the entire door panel. Start at the bottom. Near the top it will get tricky.
You have to sort of push the panel up from the rear while trying to "unhook" it from the door sail that's secured to the door in front. Play around with it. You'll know when everything unhooks.
And then you should have access to everything in the door.
And when you blinker is superfast, it usually means you have a light out somewhere. Try doing a check.
95naSTA
Sep 21, 2015 06:50 PM
lkiller123
Sep 21, 2015 03:00 AM
