Buying PFI Turbo Kit w/ intercooler and turbonics 60-1 what do i need to know?
what do i need to know after buying the kit? what other things am i going to need to buy after this kit? what is the best way too upgrade the fuel delivery?
I already have the following usable mods on my car already.
Cattman Headers
Random Technology Cat 2.5
Stillen B-pipe 2.5
Stillen Muffler
Middle Eastern Variable Intake Manifold
ACT Stage 1 Street Clutch
Fidenzia Flywheel
Unorthodox Drive Crank Pulley and Belt
Suspension:
Tokico Illumina adjustable Shocks
Stillen Front Strut-bar
Stillen Rear Strut-bar
Stillen Rear Sway-bar
Eibach Springs (1.5” Drop)
I plan on Upgrading the exhaust to a 3 inch sooner or later after the turbo.
Cattman Headers
Stillen B-pipe 2.5
Stillen Muffler
Fidenzia Flywheel
Suspension:
Also i wanted to make sure just in case. Can i use my headers still? the cattman headers and y pipe came as a combo. Just wondering if i can still use the headers with the Turbo kit.
i pretty much figure i need the following to get it right.
PFI Turbo Kit w/ intercooler- $4800
Blitz Dual SBC SPEC R Dual Solenoid- $467
APEX'i Super Air/Fuel Controller- $350
Greddy Emanage- $200
3” Warpspeed Cattback Exhaust w/ Test Pipe- $560
Stillen Oil Cooler- $330
440cc Injectors- ???
MAF- ???
Turbo Specialties Fuel Pressure Regulator - $150
Blitz Turbo Timer- $150
NGK type BKR7E-11 Copper Spark Plugs- $50
Greddy Boost Gauge- $133
Greddy EGT Gauge-$133
Greddy Fuel Pressure Gauge-$133
3 Pod Pillar- $60
Place Racing Motor Mounts- $260
anything else u think im missing??? that i need to add?? or any modifications u would do to my list??
MAF- ???
3 Pod Pillar- $60
MAF- ???
MAF- ???
3 Pod Pillar- $60
3 Pod Pillar- $60
No, not unless you modify the PFI reverse ypipe to accomodate the extra length of the Cattman headers over the stock manifolds.
If I were you, I'd try that. Cut down the two arms and weld them back together. Hopefully, the flanges are the same, but probably not.
Also, I haven't seen a PFI ypipe in A LONG TIME and I've only seen the Cattman headers in pictures, so the arms could be way off and require a bit of bending or extra tubing. IMO, definitely worthwhile, unless you need the money from the headers for other mods.
Two more things...
The Emanage w/injector and ignition harness is $345, however once you add all the trimmings like support tool, RPM harness, MAP sensor, etc. it is close to $600. Also, you might consider getting the Greddy Profec e01 for $515 instead of the "Blitz Dual SBC SPEC R Dual Solenoid- $467 ". The e01 display is worth it IMO and once you get an AEM wideband or similar, you can tune and log on the fly using the e01 display.
Last, you might hold off on choosing that 60-1, just yet. I'm putting something together that might change your mind on which turbo you need/want.
Okay so here is my upgraded list
PFI Turbo Kit w/ intercooler- $4800(www.ptuning.com)
The kit comes with : Includes all boost pipes, oil lines, mounting hardware, FMU, intercooler, fuel pump Upgrade to a Turbonetics 60-1 turbo.
Greddy PRofec E-01 EBC/ w/ built in Emanage Prog- $577(www.ptuning.com)
Greddy Emanage Control Unit- $310(southwestautoworks)
AEM adjustable Fuel Pressure Regulator - $170(www.ptuning.com)
Greddy Turbo Timer- $150(www.ptuning.com)
Greddy Oil Catch Can- $100(southwestautoworks)
3” Warpspeed Cattback Exhaust w/ Test Pipe- $695(Call Warpspeed)
Stillen Oil Cooler- $330(www.Stillen.com)
3 Pod Pillar- $60(Custommaxima.com)
Greddy Boost Gauge- $133(www.ptuning.com)
Greddy EGT Gauge-$133(www.ptuning.com)
Greddy Fuel Pressure Gauge-$133(www.ptuning.com)
Place Racing Motor Mounts- $260(www.cattman.com)
NGK type BKR7E-11 Copper Spark Plugs- $50(Local Nappa)
Im still a little confused as to were i can order the following parts:
300z MAF- $
Walbro 255lph- $
550cc Injectors-$
"The Emanage w/injector and ignition harness is $345, however once you add all the trimmings like support tool, RPM harness, MAP sensor, etc. it is close to $600. Also, you might consider getting the Greddy Profec e01 for $515 instead of the "Blitz Dual SBC SPEC R Dual Solenoid- $467 ". The e01 display is worth it IMO and once you get an AEM wideband or similar, you can tune and log on the fly using the e01 display."
-Okay well im gonna go with the greddy profect now. What other little things am i going to need other than the list i have? basically i wanna do it and do it right if you know what i mean. Please help the best ya can thanks
get the .5x or7x exhaust housing AR, DO NOT GET THE .82!
-hmm i dunno what that means plz explain more
300z MAF- $
Walbro 255lph- $
550cc Injectors-$
Try THIS.... http://forums.maxima.org/showthread.php?t=327382
http://www.gruppe-s.com/Greddy/greddyelec.htm
300z MAF- $
Walbro 255lph- $
550cc Injectors-$
300z MAF- $
Walbro 255lph- $
550cc Injectors-$
Walbro is $90-$110 lots of places, just look around.
550cc can be had from www.courtesynissan.com, but are expensive. Check ebay and others for SR20DET compatible injectors.
The turbo kit is sold ... sorry!
If you wait about 1 month more, you can forget about buying MAF (you can throw the MAF away! My system will be MAP based. You can forget about emanage or S-AFC etc ... I will have a standalone ready by then!
If you want to get the turbo kit, get the bare essentials first. For fuel control, the FMU should be good to start with. Heck, even if I don't get it done in a month, you haven't lost anything but a little time! The cam and crank triggering are more complex than I had anticipated, but I think it should be OK.
Depending on which year of 5th gen. 2000-2001 should work with the same setup as 1995-1999. Nissan had a terrible habit of changing stuff even within years, as long as the ignition stuff and ECU triggering (crank and cam) is the same there shouldn't be an issue.
2002+ I believe they changed the cam and crank signals. I know for sure they did on the 350Z but not sure about the Maximas.
Originally Posted by MyownNismo
Is that going to work with the 5th gen too.
t6378tp
Sep 29, 2018 04:27 PM
