Mass Airflow Sensor (MAF) removal...
I'm going to have to replace the airflow meter in my '86 max, but it seems so buried under the aircleaner box assembly, does anyone know the easiest way to get to it and remove it? Pics would be really helpful if possible, thanks!!!
Originally Posted by Dayle97SE
I'm having trouble trying to remove the air box, I cant see which bolts are actually holding it in.
IIRC, there are three at the top that are easy to see, then there are
two under the airbox that are a PITA.
It's usually best to remove the battery to get to the bolts that are
under the airbox.
Becareful so you don't lose the rubber insulators as you pull the bolts
out of the bottom, they slide into a "U" shaped channel.
Hope this helps!
Scott
Well its kinda strange, in times past when i've changed out my air filter I would notice a little bit of water sitting in the bottom of the box. This time, when my max was running real bad, there was no water, but it just wouldn't rev past 2k rpm and thats what led me to suspect the MAF.
Ah yes I remember that issue. Basically what happens is the AIV dumps water in the airbox. This water goes through the MAF and fries it....so the ECU runs the car in a "safe mode" which prevents it from revving past 2k rpm. You might want to disconnect the AIV hose from the airbox, and either put a breather on the hole, or plug it so no unfilter air gets in. It seem to be really typical for these cars.
S
S
Sarin,
What is the AIV? Is that the part you have your breather filter on? I had one on the same spot you had one but mine fell off now I am just leting it breath with no filter....the car runs much better/quiteter with it pluged does it really need to be open? Could this be causing my funny idle and problems on hot starts?.... After my intake install my car ran best with that part pluged, but I un pluged it because I was not sure if I was doing damage...let me know.
-Carson
-Carson
S
S
Yeah it is, besically it injects air in the exhaust stream to help emissions. It's pretty noises, almost sounds like an exhaust leak, but it can also backwash moisture from the exhaust back into the air box....hence the MAF failure. I don't think it really plays a role on idle because it grabs unmetered, but filtered air.
S
S
Carson,
Aside from the engine not going past 2k rpm, the idle was incredibly shaky and when I gave it gas it would stumble and hesitate severely, and sometimes even stall out.
Sarin,
Thanks for the tip on the AIV hose, I'm going to have to try it and see what kind of results I get.
Sarin,
Originally Posted by cardana24
Sarin,
-Carson
-Carson
pluging it and putting a filter on it are two different things. I am hoping I can plug it but I dont want to hurt anything. I know there is nasty stuff in the engine bay...I would like to plug it if I can.
S
Originally Posted by Drjmaxx88
Air injector valve.
The breather you have should be plugged if your not using a filter with it. Nasty stuff lurks in the engine bay. Plug it, or get a little filter for it either way is cool.
thats a big screw if it can plug that line....I'll do something with it though...thanks....why do you have a breather filter on yours if it should be pluged then?
Easiest way, removed the vacuum line to the valve, and plug the line with a screw. Then it will stop activating.
S
S
I was saying the vacuum line itself. If you plug that, then the AIV will stop working. It's a pita to cap off the bigger hose. As for mine, at the time, I just put the filter on so it wouldn't look like crap having this hose dangle around (though the way my AIV and vacuum solenoids hang now....it looks like crap!
....but this was before I had the CAI). Either way, you can put a breather on it, or you can disable it all together, it really doesn't make a big difference.
S
....but this was before I had the CAI). Either way, you can put a breather on it, or you can disable it all together, it really doesn't make a big difference.S
I do not have a picture of it but I can remember that the one I got to replace it is plastic and I just contacted the guy who sold it to me and it happens to be for a 89-94 Nissan Maxima, right now I am just pissed and I need a 1986 Maxima AFM. But if anyone wants this one they can have it!
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
