V-band clamps for BOV, WG, turbine? Good/bad?
Old Aug 31, 2004 | 09:10 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Any opinions on the benefitis/drawbacks of mounts/clamps would be appreciated.
Old Aug 31, 2004 | 09:34 AM
on_alert's Avatar
they are sweet if you jack with your car alot. I have vband turbine outlet and it is dope. They are really expensive tho. Though I have never seen a Vband BOV
Old Aug 31, 2004 | 09:47 AM
IceY2K1's Avatar
Thanks...I was pretty sure the turbine was a good idea for swapping in/out the turbo, but how often do you really need to do that especially with water/oil lines.
I'm eyeballing these:
http://www.superstreetonline.com/pro...l44/index.html
Old Aug 31, 2004 | 09:50 AM
Jeff92se's Avatar
I'm needing a caw
Um why would you want to v-band a bov? Especially when most of them are flanged and bolted on? Seems like an expensive added expense.
Old Aug 31, 2004 | 09:56 AM
on_alert's Avatar
GET THE WG one thats sweetness.
Old Aug 31, 2004 | 09:57 AM
IceY2K1's Avatar
I think it's style...cleaner look not function.
[edit]
Plus, the price is roughly the same.
http://www.atpturbo.com/Merchant2/me...egory_Code=BOV
[/edit]
I'm just wondering if there any issues with v-bands such as leaking, working loose, or whatever that I should know about.
Old Aug 31, 2004 | 09:58 AM
IceY2K1's Avatar
The Tial WG is a no brainer...BOV is still a question though.
Old Aug 31, 2004 | 10:02 AM
IceY2K1's Avatar
Also, Jeff any difference in difficulty welding these different types of flanges?
Old Aug 31, 2004 | 10:05 AM
IceY2K1's Avatar
I mean round/fish mouth looks easier to mount to a round pipe then square, right?
Old Aug 31, 2004 | 10:10 AM
IceY2K1's Avatar
Here's the 3" V-band turbine adapter:
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
Old Aug 31, 2004 | 10:14 AM
Jeff92se's Avatar
I'm needing a caw
I guess it depends. The first pic w/ the v-band looks easier as it's tapered to the shape of the pipe. So cut hole, mount and weld.
The other ones are just flat. You would have to cut the pipe to fit that flat flange. With a saw, it would be a pain. Might be okay with a 4" cut off wheel. With a plasma cutter, everything is easy.
Old Aug 31, 2004 | 10:46 AM
DanNY's Avatar
Ad·min·is·tra·tor
IMO...V band is very very nice set up. it's almost zero leak and requires no gasket.
but having a BOV V-band is kinda over kill. unless you're running really high pressure that needs a no gasket seal then V-band is ideal.
Jeff the WG flanges shouldn't be a problem. just keep moving w/ the weld so it doesn't heat up as much.
Old Aug 31, 2004 | 10:47 AM
Jeff92se's Avatar
I'm needing a caw
It's not the heat. It's cutting the pipe to the right shape so you can weld it.
And Wangsta, you start pricing those things yet??
Old Aug 31, 2004 | 10:49 AM
DanNY's Avatar
Ad·min·is·tra·tor
enh? the WG sits on a flange. i'm not talking about the BOV.
Old Aug 31, 2004 | 10:51 AM
IceY2K1's Avatar
Okay, it may be overkill and cost more, but great otherwise.
Now on to AN fittings, SS lines, and Mocal scavenge pump.
Old Aug 31, 2004 | 10:52 AM
IceY2K1's Avatar
Yeah, ~$600 for the pair....not bad for Tial quality.
Old Aug 31, 2004 | 11:23 AM
hlh0501's Avatar
Ice, I run Vband downpipe and Vband BOV... LOVE THEM!
Makes install/adjustment of exhaust easy
Old Aug 31, 2004 | 11:25 AM
Jeff92se's Avatar
I'm needing a caw
I went ahead and bought the Tilton. About the same price anyway. $189-ish
Old Aug 31, 2004 | 12:18 PM
IceY2K1's Avatar
hlh0501 - Thanks.
Jeff92se - Got link?
Old Aug 31, 2004 | 12:26 PM
Jeff92se's Avatar
I'm needing a caw
http://www.pegasusautoracing.com/pdfs/121.pdf
Handled the order 100% over the net. Shipped reasonably fast.
Old Aug 31, 2004 | 12:29 PM
DanNY's Avatar
Ad·min·is·tra·tor
their shipping rates seems to be "inflated"...maybe that's just for east coast.
Old Aug 31, 2004 | 12:30 PM
Jeff92se's Avatar
I'm needing a caw
Eh it was "okay".
Old Aug 31, 2004 | 04:19 PM
IceY2K1's Avatar
Well it looks like that BOV is out of the question, since I can't recirc(compressor bypass) and I just found it for a killer price on eBay.
http://www.roadraceengineering.com/tialbov.htm
Not recommended for street car that have anything smaller than a 20G turbo. If you try to put this on a street car with a 16G turbo. Your car will sound like you have a dying dolphin underneath your hood. (chirp) (chirp) (chirp)
Tial BOVs only have provisions to blow out. They can not be modified to recirculate the air. This means you need a HKS VPC or stand alone engine management system that eliminates the air flow meter.
Old Aug 31, 2004 | 04:40 PM
IceY2K1's Avatar
Well maybe not...this 4th gen has one and I've seen a Saturn with one.
http://www.sounddomain.com/memberpage/275109/1
Old Aug 31, 2004 | 07:52 PM
hlh0501's Avatar
Pressurize the maf and put the BOV before it... then it does not matter that it vents.
Old Sep 1, 2004 | 08:32 AM
IceY2K1's Avatar
When you say put the BOV before it, you mean between the turbo and MAF or between the MAF and throttle body?
Old Sep 1, 2004 | 10:00 AM
hlh0501's Avatar
Between the turbo and the MAF. By doing that, the MAF sees exactly what air is going into your throttle body.
I don't have pics of my new setup yet... but look at the other TIAL guy
Old Sep 1, 2004 | 10:21 AM
IceY2K1's Avatar
That's what I thought.
However, the MAF will see the air twice, right? Once as it passes through the normal way and then once it bounces off the throttle plate, back through the MAF, and out the BOV, right?
That's going to make it rich on shifts, but it prevents stalling?
Old Sep 1, 2004 | 05:01 PM
Bags's Avatar
VG Ridah's Biatch Hoe
That's the way mine is and it does not stall EVER
Old Sep 1, 2004 | 07:25 PM
Maximamike's Avatar
Until the throttle plate closes and all your air is blown out the BOV and then making your car run rich for a millesecond.
Old Sep 2, 2004 | 06:02 AM
hlh0501's Avatar
Theoretically, possibly. There is no noticeable effect of the air bouncing off throttle plate and being measured twice - so I do not know how big of a deal this is.
My car runs very smooth - as if it was meant to be setup this way. Never stumbles, stalls, etc. I guess it could run a little rich on shifts for a split second - but without a wideband there is nothing noticeable (no backfires, even with open downpipe, etc). And I guess I don't see it being a big problem if it richens up a bit in a shift anyways
Old Sep 2, 2004 | 09:52 AM
IceY2K1's Avatar
Thanks for the help...
Lilchikcadee
May 1, 2019 08:49 AM
Cotozic
Jun 28, 2017 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
maxima297
Sep 24, 2015 08:57 PM
followthadollar
Sep 13, 2015 09:55 AM
