She's alive!
Old Sep 4, 2004 | 07:10 PM
MardiGrasMax's Avatar
She's alive!
Its been many months since I blew third gear while tuning and testing at 14.7 psi. I rebuilt my spare trans and beefed it up. I tore down all the gear shafts and de-burred and polished every thing. I then sent the shafts, all gears and ring gear for cryo and shot peening. I replaced most of the inside hardware and re-mic'd the shiming and seals etc. I am now running Redline Shock Proof Heavy gear oil. I left the same clutch in their as I will replace it when I do the motor. She started up OK and only made a few wierd noises. I drove her for a few miles then took her up to 5psi and it was awesome, like falling in love with her all over again! Over the next few days I will push her back up to 14psi and see how she likes it. She should have less lag becuase I did switch to the .5xAR exhaust housing. Their is a track event at MIR on the 19th I am going to take her for some blasts. Since I have a daily driver now I am going to get radical with set up for the track. Now that this project is seemingly done I can clear some room in my garage and start the 3.5L hybrid build up! If any one has a hook up for 740cc or 850cc injectors please send me a PM.
Old Sep 4, 2004 | 08:08 PM
stephenlc's Avatar
sweet.
Old Sep 5, 2004 | 12:25 AM
iansw's Avatar
Uh...you had what most of us consider a radical setup for the track already.
Now your car is going to go LUDICROUS SPEED!!
Just f'ing awesome.....you are my god.
Old Sep 5, 2004 | 12:53 AM
desertmaxima's Avatar
740-850cc damn that is a lot of fuel man its a maxima engine not a M1 tank lol.
Old Sep 5, 2004 | 07:29 AM
stephenlc's Avatar
there is a 350z guy who has hks 1000cc injectors and V-con pro. But he already has a AEBS sleeved block, forged everything, he probally have the fastest 350z in the world in the with the next 6 months.
Old Sep 5, 2004 | 07:41 AM
stephenlc's Avatar
http://www.my350z.com/forum/showthre...threadid=87447
Mardi they are having a group deal on injectors and arp head studs. Aren't 350z injectors the same type as VQ30DEK? Mabe you could switch the lower and upper intake manifold of the DEK.
Old Sep 5, 2004 | 05:19 PM
hlh0501's Avatar
Congrats! keep us updated
good luck at the track
Old Sep 5, 2004 | 05:40 PM
|Bijan|'s Avatar
UCF Lexus
Hell yea Matt.....worth the wait eh? Can't wait for those new numbers!!
Old Sep 5, 2004 | 07:29 PM
Tatanko's Avatar
Bacon Lover
Can't wait to see some new numbers and maybe some new pics
Old Sep 5, 2004 | 08:08 PM
Confused's Avatar
Permanent Maxima.org Resident
good news!
Old Sep 5, 2004 | 08:12 PM
Bags's Avatar
VG Ridah's Biatch Hoe
AWESOME.
Congrats on getting everything done
Old Sep 5, 2004 | 08:58 PM
gtr_rider's Avatar
192.168.1.1
this should be something to wait for.
Old Sep 6, 2004 | 04:18 AM
Redmax's Avatar
Redlinemax Owner
Congrats Matt, Maybe I will come down today and drive the new toy.
Old Sep 6, 2004 | 07:47 AM
michaelnyden's Avatar
555cc nismo injectors would be enough for almost anything our cars could throw at it...I would think...how much power are you plannin on mardi?
Old Sep 6, 2004 | 08:01 AM
stephenlc's Avatar
He has 515cc right now.
Old Sep 6, 2004 | 08:16 AM
Bags's Avatar
Using this chart...http://www.rceng.com/technical.htm#WORKSHEET..
If your pushing much over 500 Crank HP, you need bigger injectors. Matt is pushing ~440 whp. So he is near the 100% IDC.
And like spanish rice said, he has 515cc now
Old Sep 6, 2004 | 08:32 AM
Nealoc187's Avatar
SLOW
555cc injectors are only 2x as big as stock, so if you think about it, you can only run 2x what the stock injectors will safely support if you want to stay safe on the 555s.
Old Sep 6, 2004 | 08:39 AM
Nealoc187's Avatar
SLOW
BTW mardi this should be awesome I can't wait, hopefully you will put down some sweet numbers.
Old Sep 6, 2004 | 11:13 AM
At 14.7 psi I was seeing 100% inj duty cycle, I'm gonna up the base FP and use the EM to adjust for it, I can do 555cc at 52psiFP, but with the new motor I'll be way past that. JWT is also rich and I can get a bit more out of her if I lean it up a bit. Im not sweating it now, just looking for a cheep hook up.
Old Sep 7, 2004 | 10:17 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Mardi,
You should switch to a DEK lower and fuel rail to run DEK injectors, you can pick up 630cc for dirt cheap or run RC Engineering 350Z injectors in whatever size you need.
Old Sep 7, 2004 | 10:58 AM
stephenlc's Avatar
Originally Posted by IceY2K1
Mardi,
Thats what I said. I give him link to 350z injector group deal.
Old Sep 7, 2004 | 12:56 PM
IceY2K1's Avatar
His motor is using side-feed injectors, he would need to convert first inorder to use 350Z/DEK injectors.
Not what you said.
Old Sep 7, 2004 | 02:20 PM
stephenlc's Avatar
Not what you said.
silly me.
Old Sep 7, 2004 | 02:42 PM
IceY2K1's Avatar
silly me.
Old Sep 12, 2004 | 06:19 AM
Back up to 14.5 psi and no problem, scarey fast! I was only in the 4.6v on the MAF and 86% injector duty cycle even at 7200rpm pulls! My PLX wideband is here and I just need install and do some data logging to see where I'm at in AFR. Track day on the 19th.
Old Sep 12, 2004 | 06:54 AM
C MAX's Avatar
dang marti and im over hear saying im getting close. now i have to wait and see if i even stand a chance. this is a turbo i presume and are you still running nitrous set up and if you are im in the works of running extra fuel via the solenoids with a activation switch when its senses boost from the s/c instead of bigger injectors. dont know if it will work but im working on it. good luck with that beast.
Old Sep 12, 2004 | 07:45 AM
stephenlc's Avatar
Sweet track day next Sundat.
Break an axel.
Old Sep 13, 2004 | 02:25 AM
kenji's Avatar
Try not to **** your pants when you break into the 11's.
edit: again..
njmaxseltd
Jan 21, 2003 11:31 AM
ny96max
Dec 28, 2001 11:46 PM
Turbo95Max
Nov 28, 2001 08:18 PM
Empz
Dec 10, 2000 12:05 AM
