Replaced the leather e-brake cover and center console box
Old Sep 9, 2004 | 01:53 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
Let me know what you guys think, i'm planning on replacing the leather door inserts with black leather red stitching
http://www.cardomain.com/id/killcrap
Old Sep 9, 2004 | 01:56 PM
97WhtSE's Avatar
Looks ok i guess. The red doesnt really match with anything. I would of got white stiching.
Old Sep 9, 2004 | 03:04 PM
95bkackmax18s's Avatar
i think it looks good, just do a little more red here and there. i like how you put your tv ( i just got an 7 inch audiobaun and mater of fact, i put it in the same place, its like it was made for it) by the way, did you have a hard time getting the tv to sit nicely flush?
Old Sep 9, 2004 | 03:15 PM
killcrap's Avatar
its the microvison tv i bought here. everybody here i see that has them isnt centered in there cuz they have the remote control IR showing. i just re routed it to opening next to the dimmer switch. but anyway it fits flush, and had to get some zip ties in there also.
Old Sep 9, 2004 | 03:26 PM
hey, matter of fact mine is the way your describing, its a little bit more to the left cause of the romote control IR. ( is that what you call it, yea, the thing you need to get the signal) are you saying you removed it from the tv and replaced it? please tell me more.
Old Sep 9, 2004 | 03:58 PM
killcrap's Avatar
on the inside of the tv there were 2 screws holding in the IR Unit, i unscrewed it, and desoldered the conections and made a new connection that was 2 ft long so it would reach up in the spot next to the dimmer switch. drilled a hole and positioned it so the remote can still function.
Old Sep 9, 2004 | 04:21 PM
i might have to look into that, thanks
Old Sep 9, 2004 | 04:32 PM
Taken2DaMax's Avatar
Black doesn't really match tan leather but the stiching looks good. I especially like the setup on the center console. I'd give it a 7 out of 10.
Old Sep 10, 2004 | 08:19 AM
d280c's Avatar
Looks great! Tell me how did you affix the center armrest leather to the base. I got a cover a few weeks ago, have not fully install it yet but I am finding that mine has a slightly looser fit than yours, could be that I have not secure the bottom ends. how did you do this? Also did you use any adhesive below the cover?
Old Sep 10, 2004 | 11:49 AM
killcrap's Avatar
to get the armrest cover to fit, i first tired to remove the stock one, there was some adhesive on it but i carefull removed the leather from the underlying fabric. then i test fitted it with my aftermarker leather, and it was loose. so that was a failure. so i put the stock one back on and put my aftermarker one over the stock leather, and it worked like a charm. all you have to do is pull up the original leather to the point where it folds under the cover. and match it up with the aftermarket one if that makes sense. then you'll need to do some stretching so you can get a snug fit, and then put the excess leather under the box and put the 4 screws back in.
Old Sep 12, 2004 | 06:28 PM
d280c's Avatar
Great ! Thanks for the advice.
vingodine
45
May 21, 2016 12:46 PM
maxipower
Aug 21, 2015 11:10 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
