newbie questions about C.V. joints...
1997 max GXE
2 hopefully simple questions i would love to get answered. went to autozone to order new left n right CV joints. they wanted to know if it had limited slip, which im pretty sure it doesn't and if i have ABS on it or not. the last one i wasn't so sure about since i've never been in a situation where i would notice it. is there a n easy way to figure this out? maybe decode the VIN or something. 2nd question is ; do i need a front end alignment after installing, it seems to make sense but i'd like to be sure. appreciate the help, thanks
from stinkin hot louisiana,
wb
wb
Originally Posted by wbakker
1997 max GXE
wb
wb
Second, No it don't have limited slip but to find that out you will look under the hood on the passenger side on the VIN # plate there is something that says Trans axle# if you C a letter V in that line of letters that means you have limited slip if not U don't
Thirdly, Yes you will have to have a front wheel aligment
Originally Posted by MAXDADDY98
First, yes your car has abs
you have to look behind the rotor around the cv joint. there will be a toothed ring, like a gear. if that is there you have abs. if its not there, you dont have it.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
