Which ignition wires to splice into for positive and negative?
Old Sep 10, 2004 | 07:36 PM
Ladzio's Avatar
I need to power a switch inside the car which I will put next to the cruise control. What are the wires on the steering column that I could splice for positive and negative.
Thank you!
Old Sep 12, 2004 | 06:55 AM
Ladzio's Avatar
hmmm.... one more time...
Old Sep 12, 2004 | 07:27 PM
Ladzio's Avatar
Oh come on, someone gotta know it...
Old Sep 12, 2004 | 07:34 PM
Tyrexx's Avatar
This for 95-98 only:
12 VOLTS CONSTANT WHITE/VIOLET @ IGNITION SWITCH HARNESS
IGNITION 1 BLACK/RED @ IGNITION SWITCH HARNESS
IGNITION 2 RED/YELLOW @ IGNITION SWITCH HARNESS
Loosten a bolt under there thats grounded and slip in a wire of your own, then retighten.
Old Sep 12, 2004 | 07:36 PM
Ladzio's Avatar
Thanks a ton man! Finally I can complete the project tomorrow !!!
And I suppose negative would be simply black one.... though not always...
Old Sep 12, 2004 | 07:41 PM
Tyrexx's Avatar
yup, be sure to use thick enough wire for the application and you should also use an inline fuse to be safe. What are you hooking up?
Old Sep 12, 2004 | 07:49 PM
RA030726's Avatar
I'm nutty for Nissans
what are you wiring? I would not use the stock ignition wires for anything other than a remote starter or alarm. You should get power from the fuse box.
Old Sep 12, 2004 | 07:52 PM
Ladzio's Avatar
I am wiring yellow front markers which I want to come on whenever I turn keys in ON position. I am putting a switch in between to shut them off if I will also. I thought to get power from cigarette lighter, but ignition wires are physically much closer to the button.
Will appreciate any input!
Old Sep 12, 2004 | 08:05 PM
Tyrexx's Avatar
as long at they are small and dont take many amps it should be fine.
Old Sep 12, 2004 | 08:06 PM
RA030726's Avatar
there are a bunch of IGN wires in the fuse box, take a look. They are labled.
Old Sep 13, 2004 | 12:38 PM
Ladzio's Avatar
Will take a look tonight. Thanks for input.
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
