Turning up the boost
Old Sep 12, 2004 | 12:09 PM
pimpjuice's Avatar
I just recently got my VI working correctly and noticed a .6 psi drop. I had my boost controller re-learn 10 psi and you can feel the car pull even harder now when the VI kicks in.
I want to turn my boost up to 11.5 - 12 psi but want to do it safely with the setup I have now. I want to eventually get bigger injectors and a return fuel line, but want to try this out for now.
My question is:
How do you know when the car is knocking/detonating? Are you using an OBD to tell you or just listening for it, or are most of you just relying on J&S to pull timing as knock is detected? My car is pretty loud so listening for it is out of the question (unless I'm at a dyno).
Right now my A/F ratio is at 11:1 and I am pretty confident in keeping it that way while turning the boost up.
Old Sep 12, 2004 | 12:34 PM
stephenlc's Avatar
I would like to know also. How much advance retard per pounds of boost?
Old Sep 12, 2004 | 12:41 PM
pimpjuice's Avatar
I retard 1 degree per psi of boost and 2 degrees per psi after 5800 rpms
Old Sep 12, 2004 | 05:58 PM
MardiGrasMax's Avatar
J&S is cheeper than a motor swap,
Old Sep 12, 2004 | 07:35 PM
hlh0501's Avatar
Not bad...
but wouldn't you want the most retard at peak torque, and if anything add a little more timing back in after that (on the 5800+)?
Old Sep 13, 2004 | 01:18 PM
pimpjuice's Avatar
Originally Posted by hlh0501
Not bad...
That would be ideal, but I wouldn't know how much timing to add in the higher rpm range. I guess I just need to get the J&S and watch it to see when it starts detecting knock.
Old Sep 13, 2004 | 01:21 PM
hlh0501's Avatar
Yep. Just a suggestion, something that would be more safe, and more power producing. Ramp up to your 1-2deg/psi retard at peak torque, and stay constant from there - or add back 1 or 2 degrees in the higher revs.
And I agree, J&S is a good unit for ignition - not having to worry about this stuff!
Old Sep 13, 2004 | 03:04 PM
pimpjuice's Avatar
Thanks for the help, I'll get on the dyno and try this out. The only problem with my ignition setup (greddy) is that right now its boost dependent. I don't want to run MAF voltage dependent all the time since it would pull timing when I'm not boosting. Maybe I'll set up the MAF voltage map and switch to it when I plan on being at WOT the whole time (ie: for a race).
Old Sep 13, 2004 | 04:18 PM
hlh0501's Avatar
Thanks for the help, I'll get on the dyno and try this out. The only problem with my ignition setup (greddy) is that right now its boost dependent. I don't want to run RPM dependent all the time since it would pull timing when I'm not boosting. Maybe I'll set up the rpm map and switch to it when I plan on being at WOT the whole time (ie: for a race).
With emanage you can use the MAP vs RPM table, and have best of both worlds... that is what I do. no switching, etc.
Am I not understanding?
Old Sep 13, 2004 | 04:57 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Like retard 2 degress @ peak TQ/5000 rpm and add 1 degree back @ 6000
good idea.
also run WI and add more timing
Old Sep 13, 2004 | 05:02 PM
Jade95Maxima's Avatar
not to sound retarded but what is J&S?
Tony
Old Sep 13, 2004 | 05:20 PM
hlh0501's Avatar
or meth...
jade: J&S = J&S Safeguard , a unit that retards timing by knock - for each cylinder. So you can get the maximum possible power (from advanced timing), while being safe from knock.
Old Sep 14, 2004 | 10:12 AM
pimpjuice's Avatar
I use the pressure sensor so I can map boost (KPa) vs rpm.
So you use the MAF Hotwire Voltage vs rpm then?
The only problem I see with that is that you could still be pulling timing under vacuum.
Old Sep 14, 2004 | 10:23 AM
pimpjuice's Avatar
good idea.
I don't know if you meant 2 degrees total, but I would pull 2 degrees per psi you see at that rpm, then 1 degree per psi after.
It might look something like this:
At 10 psi:
5000 rpm : pull 20 degrees
6000 rpm : pull 10 degrees
Old Sep 14, 2004 | 10:39 AM
hlh0501's Avatar
woah too much confusion in this post!
Two things to address:
1. I would not advance back that much timing on the top end (20->10)... I personally back off 1->3 degrees TOTAL after peak torque.
SO, example 10psi:
4000rpm : -15deg
6000rpm : -13deg
2. I use pressure sensor (MAP) KPA vs RPM for ignition, sounds like same as you. You mentioned the problem of pulling timing under vacuum.... why?
On mine, I have it set to not touch the factory timing under 2psi across the board. Therefore knowing, at any given rpm, under 2psi, I am running factory timing.
Old Sep 14, 2004 | 10:58 AM
stephenlc's Avatar
http://www.mohdparts.com/emanage/
http://www.mohdparts.com/emanage/spe...translated.jpg
What about the knock sensor adapter instead of the rpm one? Or do you use them together? Its only $20.
Old Sep 14, 2004 | 11:00 AM
pimpjuice's Avatar
SO, example 10psi:
4000rpm : -15deg
6000rpm : -13deg
True, thanks. I change timing gradually anyways, I just used a goofy example.
In one of your above posts:
You mention MAP vs RPM and I mistook it for MAF Hotwire Voltage vs. RPM. If someone were to use that setting on the e-manage they might be pulling timing in vacuum.
Now that I am on the same page, I just need to get on a dyno and adjust my ignition map using the same boost vs. RPM setting I have been using.
Old Sep 14, 2004 | 12:08 PM
Bags's Avatar
SO, example 10psi:
4000rpm : -15deg
6000rpm : -13deg
I was thinking more like this EXAMPLE..
4500 rpm pull 1 deg of timing for ~10 psi
5000 rpm pull ANOTHER deg of timing for ~10 psi
5500 rpm Keep it @ -2 deg retarded
6000 rpm ADD 1 deg of timing back in for ~10 psi
6500 rpm Keep it @ -1 deg retarded
Now, I have no experioence with this, just using waht I have read.
If this is the dumbest thing since the FLOBE, sorry
Old Sep 14, 2004 | 02:15 PM
hlh0501's Avatar
Bags,
I would suggest more than 1 or 2 degrees total retard. I retard a little less than 1deg PER PSI. So at 15psi , ~12-13deg retard for me; and many retard 1+deg PER PSI.
Pimpjuice, glad we are on the same page.
Bags, one other thing - you really need a dyno of your specific application to know where to ramp up and down from in sense of ignition retard (to maximize power). It's not like we're talking about the end of the world here, but a few free ponies if you have a dyno to look at. I know it wasn't intended for this, but lets use your example - on my old dyno where it peaked 496wtq at ~4500rpm
http://www.fastmaxima.com/images/HlH...20Printout.jpg
(MY IGN SETTING)
10psi:
2500 -6
3000 -7
3500 -8
4000 -9
4500 -1 -9
5000 -2 -8
5500 -2 -8
6000 -1 -7
6500 -1 -7
7000 -7
* For anyone who does not have a dyno of their OWN VQ:
I would suggest -1deg (or more)retard PER PSI, ACROSS THE BOARD.
Oh, and what's the FLOBE? or if it's that dumb, maybe I shouldn't ask?
I'm not an ignition god either.. I can be wrong.
Old Sep 14, 2004 | 02:46 PM
JeffesonM's Avatar
living out of a maxima...
ooh, finally a question in this forum that I can answer!
http://www.flowbee.com/
Old Sep 15, 2004 | 12:03 PM
Bags's Avatar
And yeah the vaccum hair cut device.... bad idea
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
gavin68
Sep 18, 2021 12:36 PM
RealityCheck
Oct 2, 2015 06:34 PM
