Anyone ever use or have stock Lexus rims?
Anyone ever use or have stock Lexus rims on thier Maxima?
Maybe something like this:
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
I've seen alot of sets go for pretty good prices, and I thought they wouldnt look bad.
But IS300,GS300/400,LS400 & RX300 are all 5x114.3 arent they?
btw, I think some will "flame" us for tryna get non-nissan/infiniti OEM rims... but I think some of the Lexus rims would be nice if they fit, plus if you needed a good rim/tire pakage for winter or something... you know
no bolt pattern is correct... http://www.discountedwheelwarehouse...._Reference.cfm
Originally Posted by Jeff92se
Offset is not the problem. It's the hub bore and stud hole size that's the problem.
hub may be diff....... but the size of the studs is the same for Nissan and Toyota .. both are 12mm... pitch is diff..1.25 nissan and 1.50 toyota.... I know Acura hubs are smaller... 64mm to our 66mm hub .... I don't know the Toyota hub size
They will not directly bolt on. You need the hub bore increased to 66.1mm and the stud hole size might not be correct. Also there might be rubbing problems if you run anything bigger than the skinnny stock tires. For all the hassle, it's not worth it IMHO. I'd run Ford mustangs rims before Lexus rims. Obviously of course.
Apr 16, 2020 05:15 AM
