Strange hesitation in 4th and 5th ONLY...look inside
I noticed that i am getting a strange hesitation in 4th and 5th (5MT).
It happens when I am cruising along, and usually around 60 mph, though it has happened above that speek. RPM are around 3K (give or take a few) in 4th and a little lower in 5th. If I go to accellerate, I get a strange result:
First, I can hear the engine noise build. After this, the RPM slowly climb a few hundred, BUT THEN they fluctuate a few times, by a hundred or so RPM. The same thing seems to happen in 5th, but the RPM are a bit different. I am trying to isolate speeds and engine RPM, btu it ifs hard to do that while watching traffic. Also, the highways here are 55 mph, so I have to watch for cops while experimenting.
I have several KNOWN problems in my car, which may or may not be contributing:
1. POSSIBLE exhaust leak between the B-pipe and the muffler, due to no gasket there. It is also POSSIBLE that the piping has a small leak.
2. CEL from an EVAP canister and valve problem.
3. CEL for KS, BUT every source (even the dealership service department) says that it is just an after-effect of the EVAP codes.
Mine hesitates too, (auto) at 38mph when transmission is in 4th gear (overdrive) , i step on the gas almost to the point of WOT, and nothing happens - no kickdown to 3rd - just slow build up of RPM's till 3500 -3800 than it moves but it feels so sluggish.
All the maintenance is up to speed, I have hacked air box . NO CODES ... Knock sensor has 15k on it.
I will try to clean the MAF sensor, and i will look at coolant temp sensor.
also the throttle position sensor is resonsible for providing ECU with inputs that relate to engine load and driver demand.
Nick.
Nick.
http://forums.maxima.org/showthread.php?t=323971
May be the same thing I am getting...people say it may be the MAF gettin old
-matt
-matt
matty-
I will read over the links in the link there, btu one note i that I have all stock tranny components. Also, I am at about 108-109K.
I could use a tranny fluid change...
anyone shed some new light on this, i have the same EXACT problem, i twas really bad at first with a small intake, i replaced it with stock, helped a bit, then chagned my fuel filter and PCV valve, and it took about 80% of the problem away, but its ongoing
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
Sep 24, 2015 06:56 PM
