Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
How do you clean sunroof cover?
Old Sep 20, 2004 | 02:16 PM
TMaxx's Avatar
How do you clean the top part of the cover for the moonroof? like if you were looking from outside the car looking in the moonroof with the cover closed you see a bunch of dust and dirt. My vacuum cleaner can't reach in there when I tilt the roof. I was wondering if there was a way to do this.
TMaxx
Old Sep 20, 2004 | 04:28 PM
99se5spd's Avatar
while its in vent take the glass out...im not sure how, ive never had to on mine but its usually just 2 torx screws on each side.
Old Sep 20, 2004 | 06:00 PM
RA030726's Avatar
I'm nutty for Nissans
you can take tha glass out:
2 phillips screws (plastic) they hold on the plastic trim
4 10mm nutts ( i think its 10mm) and thats it!
Just make sure you remeber where the shims are. they hold the glass up a bit at each side, so it is even with the roof. put them back in the same places.
Old Sep 20, 2004 | 07:45 PM
Dave Holmes's Avatar
remove the glass like the above post (I've done it, not hard). Or use a leafblower to blow it all out. Then either vacuum or blow out your interior.
An alternative would be small crevice atachments on your vacuum hose. I have a micro set (for computers) that work fairly well, but because of their small size they take a while to do a good job.
Dave
Old Sep 21, 2004 | 06:49 AM
TMaxx's Avatar
Alright I'll look at it when I get home and see how hard it looks. I get nervous taking things apart, with my luck something always goes wrong like I loose a screw or strip a screw etc... but I'll give it a try.
Thanks - TMaxx
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
Blkkn8
Sep 15, 2015 06:57 PM
Vequity
Sep 10, 2015 05:26 AM
mikebla
Sep 3, 2015 05:37 PM
