Necessay to replace control arms w/.......
Old Sep 21, 2004 | 06:17 AM
TIG's Avatar
TIG
intrax springs? Just curious because I'm planning on replacing my ball joints, I get a nasty pop when I'm turnin left on bumps. My half shafts are new
Old Sep 21, 2004 | 07:10 AM
-shock211-'s Avatar
you don't need to replace the actual control arm but take a look at the control arm bushings. if they appear worn out or cracked, it wouldn't be a bad idea to change them and get it over with.
Old Sep 21, 2004 | 07:26 AM
TIG's Avatar
TIG
I'll check em out. Anybody running camber kits w/ an intrax drop.
Old Sep 21, 2004 | 07:53 AM
Matt93SE's Avatar
STFU n00b!
there's no need to change control arms with any suspension change. on a 10 yr old car, I can just about guarantee that your bushigns are worn out though. but you can swap those out buying OEM bushings or energy suspension bushings.
http://www.4dsc.com/articles/suspens..._bushing.shtml
Old Sep 21, 2004 | 08:06 AM
XmaximaX's Avatar
You don't need to replace the control arms, just unbolt the ball joint seperate it from the knuckle, and put the new one in. I would recommend putting the poly bushings in i think that matt sells them, i put them on with a factory suspension and a FSTB and noticed a **** ton of diffrence, they are not that bad to put in as long as you have access to a lift, and an impact.
Old Sep 21, 2004 | 10:47 AM
TIG's Avatar
TIG
Thanks for all the info all I thought I read somewhere on here that oem control arms caused some camber probs w/ intrax or lower. I realize that normally you would not need to replace these! Engery Susp inserts and ball joints need to come soon!
Old Sep 21, 2004 | 11:06 AM
internetautomar's Avatar
mod or sell?
the camber problem is resolved by getting camber bolts
Old Sep 21, 2004 | 11:25 AM
-shock211-'s Avatar
or by widening the hole to give play for adjusting camber
Old Sep 21, 2004 | 11:39 AM
mod or sell?
and creating unseen stress cracks
Matt93SE
May 24, 2019 02:58 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
maxocar
Aug 21, 2015 12:57 AM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
