Necessay to replace control arms w/.......
there's no need to change control arms with any suspension change. on a 10 yr old car, I can just about guarantee that your bushigns are worn out though. but you can swap those out buying OEM bushings or energy suspension bushings.
http://www.4dsc.com/articles/suspens..._bushing.shtml
You don't need to replace the control arms, just unbolt the ball joint seperate it from the knuckle, and put the new one in. I would recommend putting the poly bushings in i think that matt sells them, i put them on with a factory suspension and a FSTB and noticed a **** ton of diffrence, they are not that bad to put in as long as you have access to a lift, and an impact.
Thanks for all the info all
I thought I read somewhere on here that oem control arms caused some camber probs w/ intrax or lower. I realize that normally you would not need to replace these! Engery Susp inserts and ball joints need to come soon!
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
soon2ownmax
08-13-2015 02:19 PM
laparka66
08-06-2015 09:36 AM
