Problems with interior Air blower, Need help
Old Sep 21, 2004 | 09:59 PM
Zamorskii's Avatar
My interior air blower sometimes works and sometimes does not.
When I just bought the car half a year ago it also acted up, but whenever I would give it a punch under the dash on the right side, it would start working again. I thought it was some sort of bad contact, but now I do not think so.
I noticed that when I put air selector (or whatever those buttons called) on windshield/low and temp on hot, it works then when I choose front/low it works again untill I turn AC on. Air flow stops, but when I turn AC off I can feal a blast of cold air and nothing after.
What can it be? Can it be a bad control unit or what? How can I then justify the fact that a punch used to work (not any more )
Sorry for this little rattle. All responses are greatly appreciated.
Old Sep 22, 2004 | 02:37 PM
Zamorskii's Avatar
Only 5 view for almost a day
Anyone????
Old Sep 22, 2004 | 03:28 PM
vortechpower's Avatar
dont know. try looking under the dash to find out what you were punching that made it work.
Old Sep 22, 2004 | 03:39 PM
s0ber's Avatar
Mine went bad, replace it. It seems to get stuck, you hit it, it gets unstuck...
I just changed mine.. Its easy, not too expensive either.
Old Sep 22, 2004 | 03:43 PM
SunMax's Avatar
Is it the same at all blower speed levels?
Old Sep 22, 2004 | 05:43 PM
z32drifter's Avatar
you have 2 poss problems..... no int fan... then hit lower dash...fan comes on.. that is classic blower motor failure.... the brushes are worn out and hang up causing the blower motor not to work... the hit frees the brushes and when they make contact the motor comes back on......buy and install new blower motor........... you may also be having a problem with your blower resistor... the resistor can cause blower to operate abnormally .... most of the time you will lose lower speeds.... I would replace the blower motor first and then see how the system works.... later
Old Sep 22, 2004 | 07:25 PM
Zamorskii's Avatar
Thanks, for insight guys.
z32drifter, where is that resistor located? is it on the motor itself or it's a sort of a fuse?
At first I thought that it were brushes going bad, but then noticed that it almost never works on low speed settings and a "punch technique" does not work now either.
Does anybody know what I need to disassemble in order to take that damn motor off?
Old Sep 22, 2004 | 08:12 PM
z32drifter's Avatar
I haven't looked at the motor on the Max.... I think you just have to remove the lower dash cover on the pass side.... you may have to remove the glove box.. I'm not sure.. the resistor is normally mounted near the motor.. you will only see the plug and poss the back of the resistor.... the main part is normally in the evap/blower case.. there should be a plug with 4 wires into the resistor... you can test the resistor with a volt/ohm meter.... just look for continuity across the resistor....
Old Sep 22, 2004 | 08:24 PM
Zamorskii's Avatar
thanks a lot. I'll try the resistor part tomorrow
Old Sep 22, 2004 | 11:05 PM
s0ber's Avatar
Yeah you remove the glove box, nothin else.. take a look under there you'll see it.. its not in the big black box if thats what your pounding on.. I ended up cracking that box when I was pounding on it I thought the fan was in there.. Crasked the box and it started leaking! Damn evaporator :\
Old Sep 23, 2004 | 04:45 PM
Zamorskii's Avatar
OK, I took glove box apart, here what I saw
I assume that the motor is in that white plastic case on the right. Please somebody confirm if I'm wrong.
Now I looked at resistor and measured continuity on its pins. Only 2 pins show continuity on them (marked in red). Is that right or the resistor is bad?
Do I need to take dash apart to take blower motor of that white case?
And it does not work at all blower speeds, now
Old Sep 23, 2004 | 10:16 PM
Zamorskii's Avatar
please, I still need your experience guys
Old Sep 23, 2004 | 11:05 PM
s0ber's Avatar
take out the blower, and apply power to it directly from teh battery, if it dont work, well buy a new one.. Then work on the resistor if its having problems.
Its easy to take it out so.. Shouldnt hurt much
Old Sep 24, 2004 | 08:45 PM
Zamorskii's Avatar
is the blower in that white round box?
Old Sep 24, 2004 | 09:00 PM
s0ber's Avatar
yes its that black thing on it
Old Sep 24, 2004 | 10:16 PM
Zamorskii's Avatar
O.K. I took motor off and tested it. It works. )
Now where can I buy that resistor? I'll try my local junk yard, but they are worse than stealerships.
Old Oct 6, 2004 | 06:39 PM
Zamorskii's Avatar
Update:
today I received the resistor (thanks vsamoylov), put it in, but the damn thing did not start to work
What else can be there? I tested the motor on a battery when I was looking at the resistor and it worked.
Now today after the install, I noticed that when I choose windshield defog (the very right button) something clicks in the engine bay and I can feel that rpm drops. It doesn't happen on any other button though.
Please, I need all the input I can get. It becomes kinda chilly here in Minnesota and driving w/o heat or any other air really sucks.
Old Oct 6, 2004 | 06:57 PM
njmodi's Avatar
Do I get a tax break?
That click you are hearing is the compressor kicking in... which is also why the RPMs drop slightly.
If you have verified that the blower motor works, and replaced the resistor pack, the next place to start looking is the fan/heater/a/c control head unit... see if something has come unplugged or a wire/connection is loose, etc.
Old Oct 6, 2004 | 07:21 PM
Zamorskii's Avatar
done that,
is there any way to test that module?
Old Oct 7, 2004 | 07:14 AM
Zamorskii's Avatar
can I just short some wires to test it?
Old Oct 7, 2004 | 12:43 PM
Zamorskii's Avatar
anyone, pLease
Old Oct 7, 2004 | 12:53 PM
njmodi's Avatar
PM me your email addresss. I'll try to send you the relevant pages from the FSM...
Old Oct 7, 2004 | 12:59 PM
kenju4u's Avatar
well only thing i can think of is that it is still the motor, because u connected it directly to the battery it worked fine but u cant control the variable speed that way, maybe with that it doesnt work.
Either that or something is wrong with your temprature control unit. it is not sending the power. check to see if you get power on the plug u connect to the motor at differnt fan speeds and stuff and if all that stuff is good I would just try to replace the motor and see what happens. You can always return the fan if you find out that its not the problem.
Old Oct 7, 2004 | 04:40 PM
Zamorskii's Avatar
I'll try all tha, and get back to you guys
Old Oct 7, 2004 | 05:34 PM
njmodi's Avatar
FSM pages sent via EM.
Maximan190
Dec 16, 2015 06:01 AM
GregL65
Sep 7, 2015 10:33 PM
lux97Max
Sep 4, 2015 05:42 PM
sdotcarter
Sep 2, 2015 09:53 PM
