What's in your manual tranny?
I cracked open the drain plug on the manual transaxle on my '93 SE and found it full of that red automatic transmission stuff. I know that's spec for the manual transmission of a Ford pickup I have, and maybe it's fine for the Maxima, too. Dunno.
Do you guys run the red stuff or use more traditional gear lube?
I'd run gear lube -- ATF seems a bit thin to properly protect the moving parts. MT-90 is a good synthetic gear lube that people here use.
Originally Posted by Bman
Are you sure it's not just red transmission oil and you are sure it really is ATF?
MT-90 is red I think... (can't remember what it looked like anymore).
purple gear oil here. i've heard of people running atf if a manual tranny but that scares the hell out of me. i hear redline mtl is supposed to be thin like the atf but properly protect and lube the gears. its also available in gl-4.
Originally Posted by nubiannupe
So, I guess black fluid in my gear box is a BAD thing, huh?
(disclaimer - I'm just joking, btw... I'm running redline! )
Thats alot of mula$$$
I use Royal Purple i believe it said it is compatable with Gl-4 and Gl-5. Not sure but my maxima loves this stuff. When i change my gears i noticed a much smoother gear shift. My rpms seems to be a little better too like it picks up fast but this may be in my head. THis stuff is like a thick purple goop and is like 8 bucks a bottle. I definately reccomend this stuff for your tranny
tarun900
19
Dec 20, 2021 06:57 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
