question about bass tubes?
Would a bass tube work good in a 5th gen trunk or would it create too much rattle like mt 2x12in subs... i was thinking of getting like a 10 in bass tube, but only if it will not create too much rattle and make it sound good without using too much power
i did that already , but i wanna get rid of the 100lb box and replace it with something lighter and something so i can use my trunk... so will a bass tube casue rattle like my box or will it not be as noticable.
-Robert
If the tube was sealed also and they both had the same internal air space, then they would sound identical. Shape of the enclosure means nothing when comparing subs as long as the enclosures are built resonant free.
Comparing ported to sealed is also difficult unless we know the details of the ported box. Enclosure size, Fb, port size, sub, etc.
-Robert
-Robert
i want to feel the bass outside my car, would a box do this?
all my tube does is rattle, but it sounds good wen your inside the car
-Robert
ok, because i was just wondering if i should spend the money and get a box, or keep the tube, so i guess ill keep the tube but upgrade the sub. i dont know if you know alot about subs, but how do you think a kicker comp vr would sound in a tube? it has 500watts peak, and my amp pushes 400 continous watts at 4 ohms with a peak of 600watts. rite now i really want the bass to be felt outside the car. i want to be able to be outside of the car and get hit by the bass lol neways thanx alot for the info
-Robert
wow thanks for the info man, i mean its easy for me to comprehend and understand automechanics lol but wat u jus said i dont think ill ever understand electroniics.
i dont know about all that fb and hz stuff[not to sound stupid, lol i guess i shoulda payed attention in pphyics.], but the tube is ported, and has a little curve on it like a feedback hole which air comes out of, its about 2feet long, not really all that long, its a smaller tube, but it wholes a 10inch speaker. its at the right side of my trunk facing the tail light and the speaker is about 4 to 6 inches away from the taillight, and the tube is tied down the right side along the trunk
I think your problem may be that the bass tube you're using is not very good. I've used a pair of 10" tubes that would rattle your fillings loose.
What kind of tube do you have?
The advantage of a bass tube to a traditional enclosure is that it's removable and offers good bass response for it's size. A bass tube usually offers more airspace in a smaller size due to it's shape (it's a geometry thing circle vs square).
It is a good choice if you chose a good one in the first place. If you get a cheap Walmart one, don't expect it to sound even decent. Those are garbage.
dam i guess u answered my ques, my friend said hell buy it for 40, but i dont want to sell it lol its been passed down to me from my uncle and my friend said there hard to find. is that true? i mean if there not hard to find ill sell it for 40
-Robert
yes its like that but without an amp. think i should sell it for 40 though? because my friend said that i should keep it for later on, because there hard to find? what to do? if i sell it im def getting a sealed box
Robert, I like to peak in on the threads that you respond in (to absorb knowledge). You have a lot of knowledge and you are willing to share it with us here on the Org. I think that this is pretty cool on your part.
This isn't my only forum. If you need help with any of the following subjects, feel free to post in the following locations. I'm checking the sites daily (except when travelling for work) and will respond accordingly.
www.hometheaterspot.com - (ID=Robert_J) general home theater, direct broadcast satellite systems, DIY audio and Mitsubishi HDTV's
www.hometheaterform.com - (ID=Robert_J) general home theater, direct broadcast satellite systems, DIY audio and Tivo
www.avsforum.com - (ID=rlj5242) direct broadcast satellite systems, DIY audio and HDTV reception via satellite and over the air
www.tivocommunity.com - (ID=rlj5242) all things Tivo related
-Robert
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Stagnet04
Oct 11, 2015 08:16 PM
