help 5speed rewire
help 5speed rewire
Ok I got the 5speed tranny in but not sure how to do the rewire to get my car to crank the 5speed plug has 4 wires and the auto has like 7 . Three of the color codes match but the other wire doesnt. And I tapped them together and got nothing Please help.
Hey,
I had the same problem. I tried 1st w/o a FSM... Boy, what a mind f**k. I could probably give you a little advice though. Start by looking at the diagrams for the starter and the other ignition components. Find the two connectors you noted earlier. I believe you have a VE because the connectors are the same as mine were (7pin auto => 4pin manual). The VG is a little different. The main thing you want to do is find the p/n (park/nuetral) switch which becomes the n/s (neutra/safety) switch in the 5spd. This allows you to start an auto when it is only in park. It also says that you can only move the shift lever when your foot is on the brake. Basically, you just cut and splice the connectors to fool the switch into doing the same thing. However, now it only starts the car when it isn't in gear. I can't remember the exact colors of the wires needed off the top of my head. I do know that a brown and red wire of some sort is involved. Just make sure you remember that the wires don't necissarily connect if they match. Look at the diagrams before you connect anything. If your not careful you'll run out of length on the wires and need to hack up your wiring harness.
Also, try a few of the other diagrams....
(1) Fold outs in back of FSM
(2) Reverse/Tail lights (for Reverse light rewire)
(3) ASCD (Automatic Speed Control Devise/Cruise Control) for ASCD cancel switch on the clutch pedal
(4) Diagrams in the section for "MT" and "AT".... manual trans and auto trans respecitvely
(5) Anything else you can think of related to your problem... remember, the FSM isn't organised the way you'd think. Use it like a phone book till you figure it out
I'll try to get back to my work on a write up asap. Check my site for it in a week or so. PM me w/any other questions...
Gook Luck,
Matt
P.S... You'll need it
Gook Luck,
Matt
hey fugi did u get my PM cuz i still need ur help on makin' my damn reverse lights to work and my cruise control as well. i'll c if i can get ahold of an FSM if i can.
Originally Posted by silverlinekenne
thanks man I m going to try that tommorw but right now I got to see why im not keepeing any brake pressure
So how'd it go? I assume since you haven't reposted that you figured it out. Let me know if ya need more info.
Lata
hey fugi i would really appreciate it if u can give me a hand on doin' this complete rewire so let me know when ur comin' down to miami and hopefully we can meet up or if u can scan that page from ur FSM and send it to me on a pm that would be really helpfull.
rick
rick
fugi u didn't reply back to my last pm just to let u know.
I've had a lot of shait goin on recently. I'll do my best to get a scan out to you soon. Hopefully you already got it goin'. If not, I'll figure something out.
Take it easy,
Matt
MaxRPM6
Sep 11, 2015 06:56 PM
TurboA32
Aug 27, 2015 08:44 AM
