What is the dyno numbers on a stock 2K Max A/T
Old Apr 12, 2001 | 07:59 PM
Max_Vader_2K's Avatar
Do any one know these numbers?
Old Apr 12, 2001 | 09:02 PM
Paul6speed's Avatar
Between 160-170 HP.
Old Apr 12, 2001 | 09:56 PM
punkdork's Avatar
Originally posted by Paul2kGXE
Between 160-170 HP.
Doesn't that just make you cry
Old Apr 12, 2001 | 10:10 PM
Paul6speed's Avatar
Yes. I think Nissan overrated this engine. (automatic Cali/Northeast emissions) Maybe we should sue like the Cobra owner's did in 1999. Mazda overrated the new Miata at 155 horse. It turns out it really is 142. An automatic shouldn't lose more than 20% through the drivetrain. My Max lost 26%.
Old Apr 12, 2001 | 11:39 PM
Mugen13's Avatar
is it really that low? b/c I know the v6 accords have around 155-160hp at the wheels stock.
most auto trannys lose more than 20% of the power when going to the wheels. like Honda's typically lose about 23-25% of the power. and just by reading this board, it sounds like Nissan built a crappy auto. tranny. UNLESS, you get a better torque converter installed, you will lose a lot of hp through the tranny..
Old Apr 13, 2001 | 12:14 AM
AznWontonboy's Avatar
damn!!! that sucks
Old Apr 13, 2001 | 07:44 AM
Paul6speed's Avatar
Yep, it's that low. See my site for 2 dyno plots. I ran with and without a cone intake.
I guess 26% loss is within reasonable limits, just up at the upper end of the scale.
Old Apr 13, 2001 | 09:25 AM
maximawanabee's Avatar
...And the 5 speeds?
Are the figures higher in the manual trannys?
Old Apr 13, 2001 | 09:37 AM
Green 2kSE's Avatar
The 5 speed tranny loses less, probably around 15%.
Old Apr 13, 2001 | 09:47 AM
Paul6speed's Avatar
For 5 speeds: stock I've seen 15-17% loss. For Y pipe and intake I've seen as low as 10% loss. That's pretty awesome.
On Hi Performance TV (TNN), I've seen race built engines lose 20% through the drivetrain.
I've heard that the 1.8 turbo VW stick dyno tests somewhere around 140 HP. This engine is obviously underated at 150 HP. The new one is 170 HP and still underated.
Old Apr 13, 2001 | 10:04 AM
Green 2kSE's Avatar
That sounds about right. I've seen stock 5spd dyno around 190hp and 186-188lbs/ft torque.
Old Apr 13, 2001 | 10:11 AM
LoveSick's Avatar
thw 5speed tested by scc was at 190hp
Old Apr 13, 2001 | 10:20 AM
Max_Gator's Avatar
That's what my 2k 5spd dyno'd to the wheels (190). That translates to 222 hp at the crank with about a 15% loss. Announced figures are at the crank.
With the SI and cattman Y - 203 to the wheels, which is around 240 at the crank.
The claims you hear from Stillen about the Y pipe and SI are way exaggerated.
Old Apr 13, 2001 | 11:46 AM
Sorry about being such a dumb@ss and I'm kinda new to mods in Max, is the Y pipe an aftermarket muffler/exhaust or something
Old Apr 13, 2001 | 12:51 PM
Wustylez
Hey, Paul is your car Cali spec???
cuz i have heard ppl said that auto 5th gen Fed spec is dynoed at 180hp???
Tim
Old Apr 13, 2001 | 03:26 PM
UMD_MaxSE's Avatar
Got Bent?
A y-pipe is the intermediate pipe that goes between the ehaust headers and the cat. check the FAQ or search for lots more info
cruce91
Sep 20, 2015 10:23 AM
MaxLife17
Sep 8, 2015 02:36 PM
Justin Kroll
Sep 2, 2015 11:06 AM
Hailstatejig
Sep 2, 2015 06:52 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
