Trouble starting up
Trouble starting up
Last Friday I had my fuel injectors replaced and since then I've noticed that somtimes when I go to start the car the engine turns over 6 or 7 times before it will catch. Now before the injectors were replaced and at no other time in the last 5 years of driving my Max have I needed to crank the engine that many times. Usually starts up in 1 or 2 cranks. Is this new intermittant problem related to the injector change or totaly unrelated. I just pulled the ECU codes and im getting the 05 05 which is good but Im not sure where to go from here. Ant suggestions??
Thanks for the suggestons. I tried leaving the key in the On position for 20 sec then crankin it but it didn't help. Maybe it is the fuel pressure reg. or the pump. I don't know but I can't help but think that it has to do with the injectors being replaced. I did have the fuel filter changed out as well but I doubt that caused the problem. I did figure out that if I give it a little gas when I crank it that it will start up but you shouldn't have to do that with a fuel injected engine. That itself kinda makes me think that it could be a fuel pressure issue but how do I diagnose exactly what it causing it?
im having some trouble once in a while but i know my engine coolant temperature sensor is bad. maybe the ECU thinks the whole thing is hot and doesnt send enough gas im getting it replaced this weekend we'll see. i think thats my problem but you dont get that code on the ECU so i dont know.
The reason I replaced all of the injectors is that I already had one go out at 110K. I am now at 139K with the same problem and don't what to pay for the labor cost to do the job a 3rd time. I purchased remanufactured Nissan injectors for about $53 a piece so the whole job with labor cost me under $450. The car runs alot better now, no lag between shifts. I bought the car with 70K on it so who knows how it was cared for.
bryants95max
Oct 2, 2015 12:52 PM
QueensMAX
Sep 15, 2015 04:14 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
