Sticking Caliper?
Old Oct 20, 2004 | 03:29 PM
kxmike's Avatar
Sticking Caliper?
I`m having a problem with one of the rear brake calipers on my 99 SE. After a few miles of driving the rotor gets very hot and I can smell brakes. I pulled the wheel off and I could turn the rotor by hand, I took the caliper off and I can screw the piston in and out with a pair of pliers. The caliper must be sticking enough to cause excessive heat from the friction, but the caliper isn`t locked up completely. Can I fix this caliper, or should I change the whole thing? I`m having trouble locating a caliper around town. What else could cause this? The parking brake is not dragging.
Old Oct 20, 2004 | 03:31 PM
NmexMAX's Avatar
dot dot dot ...
Replaceing would be best, what kind of town you live in? Just playing. . .
Autozone, Checker, NAPA, Pep Boys all should or are able to get that part.
Old Oct 20, 2004 | 03:36 PM
themills's Avatar
I think you can buy a hardware skit that goes with your caliper. It's sort of like a caliper rebuild.
I did it to mine when the calipers were loose and made this deathly soundly clackity clack sound over bumps. Since mine was too loose and it fixed it I presume it would work for you since it sounds like its just a matter of worn out parts.
Old Oct 25, 2004 | 09:05 PM
sterlingmaxima's Avatar
could be your sliders just clean them and regrease them usually the cause of the problem
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
