Mechanic Guru's Please Step-Inside. P0100 code
Old Nov 9, 2004 | 07:38 AM
ZIPPIN's Avatar
Mauja He Mauja
SES was on. Went to AutoZone:
Troubleshooting P0100
THE PCM HAS DETERMINED THAT A MALFUNCTION EXISTS IN THE ELECTRICAL CIRCUIT FOR THE MASS AIR FLOW OR VOLUME AIR FLOW SENSOR. THIS CODE POINTS TOWARDS A POSSIHBLE WIRING PROBLEM, IE: SHORT TO GROUND, SHORT TO POWER, OR AN OPEN ACCOUNT
ANYONE???????????????????????????????
Old Nov 9, 2004 | 07:52 AM
ZIPPIN's Avatar
Mauja He Mauja
I searched and it is MAF related. I put in an new MAF 8K miles ago. The car is driving fine. But it mis-fires sometimes....
Old Nov 9, 2004 | 02:15 PM
ZIPPIN's Avatar
Mauja He Mauja
anyone????
Old Nov 9, 2004 | 04:24 PM
foodmanry's Avatar
Da Roller Coaster!
Check your coil packs.
Old Nov 9, 2004 | 04:31 PM
ZIPPIN's Avatar
Mauja He Mauja
changed those the same time as the MAF...they are the updated ones with the grey dot..
can it be a wiring problem or is that just a standard thing that comes with the code??
Old Nov 9, 2004 | 06:28 PM
sascuderi's Avatar
You will get that code when the ECU receives from the MAF either a voltage that is too high or too low. This can occur if the harness to the MAF is bad, the harness connection to the MAF is loose, the MAF has gone bad, or if there is an air leak.
Hope you find the cause. Hate to think your updated MAF has gone bad.
Old Nov 9, 2004 | 06:56 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Did you get the MAF with the tube ? I once just got the little sensor piece- it only lasted bout 3 weeks till it blew out again. Don't discount the crappy MAF. I would check the connector for any damages, maybe whiggle the wires while the engine is runing and see if the engine operation changes in any way while tuggn on the MAF wireing. If all goes good... try smacking the MAF with your hand a few times- sometimes that will cause the MAF to act up and engine will die- and means the MAF is bad.
Old Nov 9, 2004 | 07:00 PM
ZIPPIN's Avatar
Mauja He Mauja
i did replace the maf witht he tube. i will check the connector.
where could be the air leak??
Old Nov 9, 2004 | 07:07 PM
past the MAF somewhere, using brake clean or carb cleaner- spraying it on the engine is a good way to tell if the engine has a vacuum leak somewhere. When the engine sucks in that stuff its RPMs will change.
Old Nov 9, 2004 | 07:09 PM
ZIPPIN's Avatar
Mauja He Mauja
thanks for the info. will look tomorrow
Old Nov 13, 2004 | 06:56 AM
ZIPPIN's Avatar
Mauja He Mauja
well never got around to checking for leaks. hoever, the SES went away after 2 days, about 250 miles. the misfiring continues at stops...what the heck is going on
Old Nov 13, 2004 | 04:14 PM
HotMax03's Avatar
Hey BlackbirdVQ, please tell me that the clip in your sig is NOT YOU???
tarun900
19
Dec 20, 2021 06:57 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
