Sponsored by:
Sponsored by: CARiD
Hows the 3.5 working out in the 3.0 ?
Old Nov 11, 2004 | 03:42 PM
waveridr85's Avatar
Well I feel like a real newbie since i havent been following it much now, but i am now thinking of doing it.
Hows it running?
Having any problems?
Has it passed inspection?
Old Nov 14, 2004 | 08:58 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
My setup is working perfect no codes except the same EGR one i had since before the swap............im looking to change some things with it soon.......
Old Nov 14, 2004 | 10:21 AM
waveridr85's Avatar
What are you planning to change? and why?
Old Nov 14, 2004 | 02:46 PM
TILLEYS99's Avatar
trying things to get more power.
Old Nov 14, 2004 | 08:40 PM
waveridr85's Avatar
sorry for the igorance and all but you used the 3.0 block with the rods pistons, rings, crankshaft from the 3.5 right? did you need to transfer the crank position sensor or did you use the 3.0 one? same oil pan right?
Old Nov 15, 2004 | 05:04 AM
stephenlc's Avatar
not the pistons, he used 3.0 pistons, he would have to bore the block to use the 3.5 pistons. Which I think he should do................... Because he is really not getting very high trap speeds.
Old Nov 15, 2004 | 06:52 AM
japmaxSE's Avatar
Go Get a Life!
NO
sorry for the igorance and all but you used the 3.0 block with the rods pistons, rings, crankshaft from the 3.5 right? did you need to transfer the crank position sensor or did you use the 3.0 one? same oil pan right?.
NO
Sorry but you two need to go back and learn about his setup hers's the thread http://forums.maxima.org/showthread.php?t=328597
I don't think this thread is going to work.....
Old Nov 15, 2004 | 09:04 AM
stephenlc's Avatar
Originally Posted by japmaxSE
NO
NO
he used the 3.5 crank and rods, and the 3.0 pistons correct? If so please stfu. That is what I said, I was saying he should use the 3.5 pistons because it doesn't seem like he is getting very high trap speeds.
Old Nov 15, 2004 | 09:32 AM
japmaxSE's Avatar
Go Get a Life!
Get your story straight before you start bashing for no reason.
I Think You guys are confused he has TWO CARS one with 3.5bottom and 3.0 heads thats his girls car. His car is 99max setup for turbo 3.5 uptop Q45 TB VI.
TILLEYS99's Avatar
3.5 block, rod, crank and pistons
Old Nov 15, 2004 | 09:41 AM
japmaxSE's Avatar
Go Get a Life!
___________________
Old Nov 15, 2004 | 12:02 PM
stephenlc's Avatar
you bored the block to fit the pistons?
Old Nov 15, 2004 | 12:19 PM
japmaxSE's Avatar
Go Get a Life!
Oh boy I give up
Tilly he's all yours.
Old Nov 15, 2004 | 01:03 PM
TILLEYS99's Avatar
block stampin says VQ35
Old Nov 15, 2004 | 02:06 PM
JClaw's Avatar
He changed the entire block that's it.
Also, the reason Tilley is getting low trap speeds (~99 mph, almost 100), is most likely because of the restrictive 3.0 heads and intake manifold.
Old Nov 15, 2004 | 04:30 PM
TILLEYS99's Avatar
But its a torque monster.
This was when i first got the 3.5 in with stock IM. BTW it was a mustangdynameter thats why #s are so low.
Old Nov 15, 2004 | 05:30 PM
JClaw's Avatar
Unfotunately my computer sucks and I can't get it to be any bigger. I see the curves well but not quite the numbers. What's the peak torque and hp?
I really think you would be trapping higher with 3.5 upper end, considering your weight and mods, even without Variable Timing Control.
Old Nov 16, 2004 | 08:18 AM
waveridr85's Avatar
Tilleys, did your gf's car pass emmisions?
Old Nov 16, 2004 | 01:28 PM
TILLEYS99's Avatar
Not sure but no CEL
Old Nov 17, 2004 | 10:25 AM
waveridr85's Avatar
When will you be attempting to pass? im very interested in that.
Old Nov 17, 2004 | 02:05 PM
TILLEYS99's Avatar
I see no problem i checked it with my scanner and it all comes up normal.....
Old Nov 18, 2004 | 06:58 AM
waveridr85's Avatar
Well, thats good to hear. does everything pretty much bolt up or no?
Old Nov 18, 2004 | 08:31 AM
TILLEYS99's Avatar
Its fairly simple aslong as you are mechanically inclined and have knowledge of putting the motor together.
Old Nov 18, 2004 | 01:16 PM
waveridr85's Avatar
did you replace the piston rings while you were at it or do any other inner work?
maxinout93
Oct 27, 2015 01:29 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
maxinout93
Aug 16, 2015 07:25 PM
kenc15
Aug 5, 2015 08:29 AM
