Problem with my DDE's
Old Nov 19, 2004 | 04:35 PM
danimsta's Avatar
well i put them on last week (friday to be exact) and they looked great
well this week on either tuesday or wednesday the whole drivers side (both angel eyes) went out... i checked connections and everything and it was fine, the passanger side still works fine and everything
anyone have any ideas? or know where i can just get 2 rings?
Old Nov 19, 2004 | 05:43 PM
2k2nyc's Avatar
You may have burned out the balast, it happened to me twice. Try replacing it with the functional one to see if that's your problem.
Old Nov 19, 2004 | 05:46 PM
danimsta's Avatar
lol wish it was just that easy
that maens i gotta take the headlight apart again
if i burned BOTH ballasts, then it means i gotta get 2 more
Old Nov 19, 2004 | 06:03 PM
white m3 guy's Avatar
your ballast should be the black box wired outside of your headlight not inside
Old Nov 19, 2004 | 06:05 PM
danimsta's Avatar
ooo ok
i see, i thought it was actually the "ring"...
ill try tonight or tomorrow with the other ballast and see
thanks
if it IS that though, can i order another through umnitza?
Old Nov 19, 2004 | 06:10 PM
yeh they charge like $5 for another one
Old Nov 19, 2004 | 06:16 PM
danimsta's Avatar
o yeah
i forgot to tell you, i saw your max at nopi!
looks sweet!!!
i wish i could ride on coilovers, but nashville roads SUCKK
Old Nov 19, 2004 | 06:22 PM
Deckdout2's Avatar
Play with my balls
another thing to check, which happened to mine, is if you have the wires coming out of the housing pinched in the cap behind the HID, that would also cause it to loose conductivity. try uncapping it and wiggle the wire a little, and see if it illuminates any. hope that helps you, it helped me....i actually had to drill a small hole and run the wires through there so it didn't pinch anymore, next i'm going to sauder the two wires together, and heat shrink that point.
Old Nov 19, 2004 | 06:36 PM
danimsta's Avatar
yeah i followed housecors tutorial for it so i wrapped the wires in electrical tape then did it..
but when they went out, i took the cap off and wiggled the wires just in case but still nothin
Old Nov 20, 2004 | 01:07 AM
crispykid717's Avatar
Bigger than Jesus
It's definitely the ballast. Same exact thing happened to me too. When I opened the ballast up it was totally fried. I called Matt and he sent me a new one n/c!!
Old Nov 20, 2004 | 07:31 AM
redstradic's Avatar
one more thing to check. i dont know if yours came with those crummy little black connectors or not. on mine they both shorted out after the first couple of days. my first guess would be to cut those little black connectors off and go get your own connectors. that is the first thing i would check before the ballast.
Old Nov 20, 2004 | 02:05 PM
Edward Lee's Avatar
It's the inverter, or what everyone else on the Org. refers to as the ballast. Umnitza charges $25.00 each. You can however get them at a local electronic store for about $5.00 or $6.00 each. My left side went out after a heavy rain and I purchased a new one at the electronic store here in town and I am back in action.
As for the cap pinching your wires, go and get yourself some wire shrink and reinsulate them.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
