Upgrading wiring harness/headlights
Could someone shed some light as to what is involved in these upgraded wire harness? I picture replacing the harness from the bulb to wherever it leads to which looks like you need to tear into an existing wire harness. Am I wrong or just stupified?
Also what choices are available (in terms of wattage bulbs) in upgraded bulbs and what type of price are we talking?
TYIA for any input on this subject.
it's pretty simple...there is a relay...2 wires goto positive battery, the upgraded wires then go from the relay and it includes the sockets so that u only plug one of the stock sockets into part of the new harness and the other stock relay u just tie off...it's really easy...u just plug it in...no cutting
So basically....
yea...that's pretty much how it works...u just add it on...well price depends on where u get it from...i got mine for $40 but they're usually around $50...and the bulbs u can use is 9004 bulbs...but now u can use the 100/80 watt bulbs
dch95, I got my upgrade harness from www.suvlights.com
It was only $35 shipped. No more melted sockets now =)
Originally posted by aznbluboy
Yeah?... what about the cornering lights... is there anything we could do to that to avoid meltdowns...??? Shed some light on us all you OG's...
The upgraded wiring harness allows you to run 80/100W 9004 bulbs without the risk of melting the stock wiring harnesses. Stock bulbs are 45/65W. Sounds like a good idea, but I would be curious to know whether this would put a strain on the alternator.
Originally posted by bdogg88
what does this mod do to your headlights??? i heard of all the ones for your blinker/side marker.. but not headlights.. shed some light on the subject please
well...using the 100/80 apc super whites...isn't really that bright...it's somewhat lighter but not super bright...if u were running other 100/80 such as piaas...then those are super bright...cause those are pure white...the ones i have apc super whites...are blue
Thanks Dan.......
Originally posted by Daniel B. Martin
This is worth reading... http://lighting.mbz.org/tech/how_to/relays/
Originally posted by EWASUP
I put in my harness today from suvlights.com. Works great. Also install, my lights I got off ebay. I have since read bad things about lights made in Korea, but I guess you learn as you go.
Paul
Paul
Are there any particular warning signs you can spot to determine of your wiring harness is being overtaxed? (beyond the obvious of dripping melted insulation).
~Gary
Signs.......
~Gary
~Gary
[QUOTE]Originally posted by Gary95
[B]
I bought a pair of Xenon Super White 9004's off an eBay vendor, the brand is Bio Light. Korean. The guy assured me that these are safe for straight replacement of stock bulbs. The rating on this buyer was great... no reports of any problems.
Gary
These are the ones I bought and I still put in the harness. Took about 5 minutes and that was only because the directions were clearly written by an asian guy. It said hook the black wire to the Earth (instead of ground).
Loooks sweet though
Paul
[B]
Gary
Loooks sweet though
Paul
[QUOTE]Originally posted by EWASUP
[B]
well Earth = ground. My dad calls the ground of a circuit the 'earth'. But he was educated under the british/asian school system, so they use words like that.
[B]
Gary
Loooks sweet though
Paul
Gary
Loooks sweet though
Paul
using a wiring harness anyway
[B]
Hi Paul - thanks for the tip. I did test the wires with the brights on and they don't feel particularly hot... But maybe I'll get a harness afterall. Sounds like good insurance. Where did you get yours and how much $$?
Btw, don't these Bio Lights look great? It's just the right whitish-blue color I was looking for. Looks expensive.
And they still light up the road nicely in bad weather. I'm thinking of keeping the stock H3 lights in my fogs, though. They seem to still work very well in tandem with the low beams. Why muck with what does the job, right?
[B]
Gary
Loooks sweet though
Paul
Gary
Loooks sweet though
Paul
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
