My floor heat don't work........
Ok my floor heat don't work. When I switch it to floor heat it just blows heat out the vents. When I switch to defrost I hear the compressor comes on but no air goes through the vents by the windshield? Any suggestions to be what is wrong? Checked fuses all are working properly
ive got the same damn problem, and it sucks. it never used to be like that, and now no defroster, no floor heat. the rear defrost works. also, the heat that blows out the vents is at like half power of what it used to be. wtf is going on?
you have auto climate or manual? i've never encountered that problem before, but you should pull the climate controls and make sure everything behind there is plugged in right. if everything is connected like it should be, the next step would be to try another climate control module (from a junkyard), and if that still doesn't work, you might have to put in a call to your friendly dealer
JoshG
Sep 5, 2015 10:10 PM
sdotcarter
Sep 2, 2015 09:53 PM
