Daniel Martin: 5 sp MT questions
Daniel:
A few basic MT questions for you:
1) I've been experimenting with trying to improve my shifting. Going down the road today I was shifting into 2nd very slowly. About midway into the full throw maybe I paused too long because it seemed to growl every so slightly at me even though the clutch was fully depressed the entire time. Why did this happen?
2) I was reading in the owner's manual about putting the MT in first or R gear when parking on hills. Should this be done with the clutch depressed before shutting engine, shut off engine, then release clutch or can I simply shut off the car and then put it in gear? In other words, can the MT be put in gear without clutch depressed?
3) Along the lines of (2) I noticed a Nissan mechanic "cycle" through the gears for some reason without depressing the clutch before he started the car so that leads me to believe putting the MT into gear with engine off can be done even without using clutch. I don't know why he did this though since the clutch must be depressed anyway for the engine to start but perhaps this is his habit from old cable, non-electronic interfaced clutch systems.
4) You have said our clutches are hydraulic, will they still engage or disengage with the engine off by depressing the pedal?
5) I know that the clutch is the interface between the engine and MT but with the engine on and in N or with clutch depressed, what keeps the transmission moving? The reason I ask is how does the transmission know not to let you into 1st gear above a certain speed etc? I know there are "synchronizers" but what keeps them in motion to be able to sense this if they are not engaged by the clutch to the engine?
Thanks in advance for the education.
2) I was reading in the owner's manual about putting the MT in first or R gear when parking on hills. Should this be done with the clutch depressed before shutting engine, shut off engine, then release clutch or can I simply shut off the car and then put it in gear? ...
... In other words, can the MT be put in gear without clutch depressed?
3) Along the lines of (2) I noticed a Nissan mechanic "cycle" through the gears for some reason without depressing the clutch before he started the car so that leads me to believe putting the MT into gear with engine off can be done even without using clutch. I don't know why he did this ...
5) I know that the clutch is the interface between the engine and MT but with the engine on and in N or with clutch depressed, what keeps the transmission moving? ...
When the engine is running and the transmission is in neutral, most of the gears are rotating. The car does not move because the gears are not engaged with each other, but they are spinning.
When the engine is running and the clutch is depressed, then all components of the transaxle will be motionless, provided...
- the vehicle is not moving, and
- there is complete disengagement of the clutch, and
- there is no friction in the pilot bearing.
... The reason I ask is how does the transmission know not to let you into 1st gear above a certain speed etc? I know there are "synchronizers" but what keeps them in motion to be able to sense this if they are not engaged by the clutch to the engine?
Daniel:
Thanks for your help. Your answers really make sense.
In regards to my first question on the "slow shift", you mentioned that during this event the components do not slow down at the same rate. Indeed, I was trying to get a tactile feel for the actual gear engagement process. As I recall, once I heard the noise I completed the gear engagement. I read about "dogteeth" on the internet. Was the muffled growl (not really a hard grinding) I heard the "dogteeth" trying to engage? Can any of them snap off in such a situation or are they fairly robust.
I will definitely take your advice on the rapid but not forced click-click method.
... I read about "dogteeth" on the internet. Was the muffled growl (not really a hard grinding) I heard the "dogteeth" trying to engage? Can any of them snap off in such a situation or are they fairly robust.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
