Fule cut of on car w/ switch
HEy. my friend has this on his honda to turn on the car you have to press the a/c button then turn the key!!! is there a way i can hook up my maxima 99 se so that i have a switch like under the dash? so no one can start my car unless they flip the switch ??????? I need HELP any one have pics or WEB sites of HOW TO'S let me know P.m or email me at munches3d@yahoo.com or just write a thread thanks alot
Look at the fuses by your left knee. Find the fuse for the fuel pump and then find the wiring that corresponds to it directly behind the fuse block. Once you find the wires, cut them, extend them to a hidden switch wherever you like and done.
Hope this helps somewhat.
go to the ignition harness and find the starter signal switch, using a test light or multimeter find the wire that has power while the car is being started (while the starter is engaged) cut and install switch there....or go with the fuel pump like Igobuk said
What's the point? If someone wants to steal your car that bad, they'll figure it out.
However, if you really feel the need to do it, you can get a battery kill switch instead. There are lots of kits available to do this type of mod.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
BobMax
Aug 15, 2015 12:35 PM
98nismomax
Aug 13, 2015 12:15 PM
kjm900r
Aug 5, 2015 07:14 AM
