starter staying engaged
Old Nov 25, 2004 | 10:21 AM
smokeydriver's Avatar
Hey,
I just replaced my starter (got the new one from advance auto) and it's still staying engaged too long- when I let off the key, it's still engaged. I know what I'm doing, but I'm thinking I may be missing a ground wire. The only wires on the starter is the on wire on the top most stud, and the wire that's got a sensor on the end. Does the bottom of the 2 studs have anything attached to it, cause mine didn't/doesn't. THANKS!
Old Nov 25, 2004 | 10:24 AM
DemonSpawn's Avatar
Is your ignition spring the key back to the ON position from START? I had a car that you had to remember to turn the key back after it started.
You may also have a defective starter. You can check by taking the starter out, put it in a bench vice and run power directly to it and see what it does.
Old Nov 25, 2004 | 10:28 AM
starter's good, car starts up fine. and the key pops outta "start" to "on" no problem
Miket2006
Mar 1, 2021 03:55 AM
leatherneck
Sep 30, 2015 09:16 PM
maxima297
Sep 30, 2015 03:32 PM
