Slamm-it, alinement Q
If you drop your car with the ground contol kit, do you have to get an alinement every time you ajust the ride height? Is the 4th gen max 4 wheel alinement capable. I heard that only the front is capable for adjustment. Is this true or false. I really don't want to unevenly wear out my tires. If the front only able to be adjusted, what do you do about the rear. Someone Holla!
Maxi-milliyon
Maxi-milliyon
The max is only adjustable for the front toe. The camber in the front and rear can be fiddled with a little by trying to get the most out of any play in the factory bolts.
As far as re-alignment after ride height changes...I have no idea. I've never even thought about that. Good question.
Yes, you will have to correct the alignment(toe)after ride height changes. I imagine the primary purpose of the adj ride height is for a weekend racer or show, which would just be a temp setting, then go back to where your alignment is set.
