p1320 or 0201 code
Old Dec 3, 2004 | 12:01 PM
sterlingmaxima's Avatar
p1320 or 0201 code
what do either of these codes mean i couldn't find anything
Old Dec 3, 2004 | 12:14 PM
Gixxer's Avatar
I just got a P1320 on my 99 and it says
Manfacurer Contrl.
Ignition System or Misfire
Old Dec 3, 2004 | 01:48 PM
bump..........
Old Dec 3, 2004 | 01:57 PM
knight71's Avatar
This should help:
http://members.dslextreme.com/users/...esm/a32-ec.pdf
Old Dec 3, 2004 | 02:24 PM
that doesn't help i need something in lamens terms not in nucler physics
Old Dec 3, 2004 | 02:53 PM
Dubbya's Avatar
VK56 Inside
I think it has something to do with a Coil Pack. I had the same code when I forgot to hook one back up. This is going back in time in my memory so dont hold me to it. Hope it points you in the right direction.
Old Dec 3, 2004 | 03:01 PM
Dubbya's Avatar
VK56 Inside
Here is some more info out of the FSM concerning that particular code.
*Ignition coil & power transistor*
The ignition signal from the ECM is sent to and amplified by the
power transistor. The power transistor turns on and off the ignition
coil primary circuit. This on-off operation induces the proper high
voltage in the coil secondary circuit
The ignition signal in the primary circuit is not entered
during engine cranking or running.
*Malfunction Dectected*
(The ignition primary circuit is open or shorted.)
*Check Items*
Harness or Connectors (The ignition primary circuit is open or shorted)
Power transistor unit built into ignition coil
Condenser
Crankshaft position sensor (REF)
Crankshaft position sensor (REF) circuit
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
