What activates the power valve on 00-01 IM.
Simple question needing a answer too. I am currently thinking of taking stock intanke manifold off and taking it to a performance shop here in MN to see if the can make a bigger better flowing intake manifold. Just need to know how it is activated.
Do you think I would get a CEL if I wouldn't use it and used a solenoid hooked up to my RSM to activate at any RPM I want. Of coarse I haven't taken apart my intake manifold yet so I don't know how big the powervalve actually is.
You won't get a CEL, there is no feedback.
You don't need to use a solenoid, but maybe a relay. I doubt it though, since the RSM should be able to handle the load.
If you want to make the VIAS switch sooner the 5000rpm, I'd just tap the ground wire from the ECU to the RSM. That way the RSM will provide the ground sooner and then at 5000rpm the ECU will provide ground, which won't do anything. However, if you want it to open later then 5000rpm, you'll need to cut/splice the ground wire to the ECU and the RSM will be in control.
Originally Posted by MAXimumHP
So if I hook up a vacuum source to one of these I'm good to go?
What I plan on doing is taking the wire that tells it to open at 5000-5200 and using my RSM to do a couple dyno runs to see if moving it would create any extra HP. I am thinking around 4000 rpm.
I'm thinking the left one is the one I need for the power valve. Sound correct? So all I need is to hook up a vacuum line here then correct? Since I'm S/C'ed and won't have vacuum, but positive pressure, when the valve needs to actuate...
Originally Posted by Stephen Max
Yes, but the vacuum chamber is incorporated into the 00vi design.
That vacuum canister would not be used at all ??
-matt
4600rpm, so switchover occurs at 4700rpm from the dynos I've seen.
MEVI guys were using 5200 or so, but the DEK needs it sooner then the stock 5000rpm IMHO.
Yes, the vacuum canister is self contained, so you just need to provide a power wire and a switched ground(RPM switch) wire to work.
Originally Posted by Haterz
So all I need is a rpm switch and a relay? I have I/H/E with no cats/UDP, do you think activating sooner would provide gains for me? If so what rpm?
dumb question - but is the rpm switch opening or closing the butterfly at 5200 - and why 5200 - is it proven to be the best setting - and has anyone tried other settings and seen any better results.
Originally Posted by IceY2K1
On the DEK it is opening allowing all runners to share air from a secondary chamber/box.
Dynos.
Dynos.
Yes IIRC, except the MEVI uses individual "butterflys" instead of a single long power valve(rod).
Both use a secondary chamber, but execution is different.
can someone explain how to hook up the rpm switch, what wire(color) do you tap into on the coil pack plug, and what wires for the power actuator go where , one for switched ground and one for power or ground(which colors)?
The power valve control solenoid has two wires, one goes to +12V and the other is to be supplied a ground at XXXXrpm.
I've never wired a RPM switch, however I have done my shift light and all it required was a +12V, ground, and a tap on the ECU-->tach wire, which I'd assume is the same plus another wire for a switched ground output that you supply to the PVCS.
anyone knwo what this piece is called or a part number??
