How do I setup my HID kit with this H4 harness? **pic**
http://s87266458.onlinehome.us/album...1160.sized.jpg
I have black housing cefiros (H4) and am installing this 6000k HID H-4 kit. Do I plug the white wire into the top notch or the right notch? Thanks guys!
Originally Posted by mclarke
lemme make a suggestion... when hooking up the hid kit... ground to a bolt or some other ground spot under the hood... if you ground through your headlight harness you are sure to burn the ground out...
Imports_only1 -- Thanks, that is what I was looking for (top notch is for low).
Also, the HID kit came with an upgraded wiring harness that runs both the ground and the positive for the kit straight to the battery =)
Also, imports_only1, how did you figure out top notch was lowbeam? I searched the net for a diagram for about an hour with no luck.
The Frye
Sep 2, 2021 11:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
