Need a Little Expert Advice on HID's
Old Sep 2, 2015 | 08:48 AM
The Frye's Avatar
Good morning all,
This is new to me, I just joined. I have a '11 Maxima SV that currently has stock halogen bulbs. I've ordered two new HID kits (35W) for my lows and fogs. My question is simply do I need to use a wiring harness to draw power strait from the battery or will the stock wiring be sufficient? Also, my plan is to remove the bolts in the side and top of the front bumper and simply "drop" it to access what I need. Will there be enough room for me to mount ballasts, run wires, etc or do i have to completely remove the bumper. Is this going to be a real *****? Any input from experience is GREATLY appreciated.
Old Sep 2, 2015 | 11:34 AM
dmcmahan12's Avatar
I just plugged into the stock harness without using the relay kit supplied with it. 2 1/2 years later with no problems. You can also remove the fender liners to get access to the headlights and fog lights. There are a couple of threads on here about how to install HID kits. Good luck.
https://maxima.org/forums/7th-genera...bo-thread.html
Welcome aboard!!!
Old Sep 2, 2015 | 12:16 PM
The Frye's Avatar
Thanks dmc. I'll def. check this out. I can't wait to get the halogen lights out. I've always loved HID but have found excuse after excuse not to make the change. I know it'll be well worth it in the end.
Old Sep 3, 2015 | 04:18 AM
dmcmahan12's Avatar
My 2012 had halogens in it when I got it and they sucked! Could not see a damn thing. You will be very happy with an HID upgrade. Get a quality kit so you are not replacing bulb or ballast.
http://www.lightwerkz.net/
Old Sep 3, 2015 | 08:13 PM
official_style's Avatar
Yo don't need to do all of that to get at the bulbs. For the headlights take the battery out and u can reach them, for the Fogs you can get at them if u take the push pins out of the front splash guard and fender liner, you don't need to take them all out just turn the wheels
Old Sep 29, 2015 | 02:30 PM
trsandrew's Avatar
Former Sponsor
A relay harness is definitely a good idea as the factory wiring on the halogen cars may not be the same as those for the OEM HID cars. As such, that specific circuit is not designed for the initial burst of energy required to fire HID components. A relay harness isolates power from the battery directly but still gets a trigger from the stock bulb connection, so it functions completely like stock while being safer than ballasts on OEM halogen wiring.
Andrew @ TRS
Old Sep 2, 2021 | 11:03 AM
Jonathanfranco's Avatar
2009 Nissan Maxima
What are the color codes for the radio
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
