For those who Bleed their brakes. . .
Old Dec 12, 2004 | 10:33 PM
MDeezy's Avatar
Originally Posted by ZECKHAUSEN RACING web site, that I found when reading about big brake kits
Must brakes be bled in a specific order?
Bleeding is done one wheel at a time. The "old timers" will tell you to start with the wheel furthest away from the master cylinder and then work your way closer. Typically, this would mean RR, LR, RF, then LF. However, it doesn't really matter if you start with the front or rear wheels, since they are on separate brake circuits on modern cars with ABS and/or dynamic stability control systems. However, you should start with the passenger side wheel and then do the driver's side.
Is this acurate or only for BMW and such, just verifying as I will bleed my brothers brakes soon, and I previously though it was RR,RD,FP,FD to bleed the brakes. Or does this web site have faulty info?
thanks
Old Dec 12, 2004 | 10:42 PM
maximase86's Avatar
I love lamp.
I don't believe there is an actual order you need to go with these cars to bleed the system...and according to what you provided it's not completely neccessary, but probably a good habit. You should just be able to start with a wheel and go.
S
Old Dec 12, 2004 | 11:47 PM
Jeff92se's Avatar
I'm needing a caw
What you need to do is consult the Nissan FSM and follow those directions to the T.
Old Dec 13, 2004 | 04:00 AM
spirilis's Avatar
...which tell you to bleed from the furthest wheel from the master cylinder (Right-Rear, then Left-Rear, then Right-Front, then Left-Front) anyway.
Old Dec 13, 2004 | 04:24 AM
Mizeree_X's Avatar
Getting back to his roots
Ummmm, no it doesn't. Maybe you should actually read your FSM. Page BR-9 of the 2001 FSM: RR --> LF --> LR --> RF. Its the same in the 3rd gen and 4th gen FSMs as well.
Old Dec 13, 2004 | 06:59 AM
MDeezy's Avatar
thanks for the responces, I thought that they each had their own lines but I did rememeber posts where people would tell them the specific order in which to bleed.
I should have the FSM that some one posted up here to download a while ago, I'll check with that, I thought it was like sprilis suggesting, but I'll check the FSM and post what it says.
Old Dec 13, 2004 | 08:15 AM
spirilis's Avatar
hmm, you're right, version on alldatadiy.com says the same... dunno what I was smoking
Old Dec 13, 2004 | 04:30 PM
MDeezy's Avatar
sweeeeet
sweet!! thanks again.
Apr 16, 2020 05:15 AM
rbuswell
Nov 17, 2016 04:54 AM
03VQMAX
Sep 25, 2015 04:19 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
vanebecker
Aug 17, 2015 08:24 PM
