Nasty smell coming from air vents
when ever i first start my car and turn eaither the heat or the a/c on this gross smell comes out like some one took a fat dump in the air vents i was wondering if anyone else was experiencing this and what they did to fix this.
hmmm. i had the same problem , i left the ac on for no joke 3 hrs, and then the next day left the heat on for 3 hrs, then the NEXT day cleaned the airvent filter thingy under the dash and Sparyed ALOT of Curve on it =) and since its been smelling GOOD !
just pull out the center vent, spray febreeze it it and let it sit for awhile. then start your car with the air on hi. spray more febreeze into the inlets under the windshiled wipers. turn it off and let it sit awhile. should fix it
I think autoparts stores sell this stuff to get rid of mildew in the ventilation system. Same thing, you spray it into the air intake (under the wipers) and it'll clean out the mold and mildew. I guess febreeze can do the same thing...
Another way to remove the bad smell.
1)Replace in-cabin filter
2)Get the heater going strong and when it's hot, spray Lysol or some sort into the holes underneeth the wiper blades. I sprayed about 10 sec.
i kno they got sumtin thats supposed to kill the smell that u spary in ur vents outside the windsheild ...also there is a soulution at auto zone that u pour into your windsheild whiper fluid and wen u got the heat or ac on hit the washer fluid and the liquid dips down into the outside vent n makes it smell nice n rosey
The way Nissan tells you to do it is replace the cabin air filter, then spray this disinfectant they sell, i think it's like lysol, directly onto the heater core and down the drain tube. Then to clean the draintube(i don't know why it comes afterwards) so that it won't let water stand and get all nasty.
MattWithTheMaxima
Jun 30, 2017 01:06 PM
95Maxi
Aug 29, 2015 09:38 PM
kirkhilles
Aug 8, 2015 10:53 AM
