Burnt out light in my 00 Climate Control unit
Old Dec 15, 2004 | 07:01 PM
spudmanmike's Avatar
Noticed today that my "OFF", "MAN", and "AUTO" buttons are not illuminated any more. Is there a replaceable bulb in this??
I never use any of these buttons, but it sure looks different...
Old Dec 16, 2004 | 12:09 PM
Guess it doesn't look too promising
Old Dec 16, 2004 | 12:33 PM
MissingMYA64.2's Avatar
This happend to me last week the left side by the **** went out along with the Auto button and fan speed. I gave it a good SMACK and tada!!! Thats what dealers charge you 200 bucks for!!.
Old Dec 16, 2004 | 12:43 PM
goldmaxNYC's Avatar
haha ...same here .. smake on the side and it's all back to normal.
Old Dec 16, 2004 | 12:45 PM
sergeo7's Avatar
you can replace the buld with a 12V bulb sold in specialty stores, but for that you will need to remove your radio with climate control and dissasemble climate control, screw the bulb out, remove the bulb from blue plastic case and remove blue rubber that on the bulb. Install the new bulb in the blue circle casing and put a blue rubber cover on the new bulb and screw it in. It's not a very complicated process, just be careful and don't break anything.
I don't remember the type of the bulb needed, but I am sure once you remove it you can find it in a specialty electronic stores like(digikey.com). it's a 12V-14V bulb. I've done this on 2 car already w/o any problems.
Follow these instructions for stereo removal.
http://www.carstereohelp.com/stereor...NisMax3Str.htm
Old Dec 17, 2004 | 06:40 PM
I'll be damned... I went out there tonight and gave it a quick rap on its left side, and IT WORKS!!! I never even thought of hitting to see if it would come back on. It actually took out more than I thought - temp ****, defrosts, and ECONO button (not MAN like I thought, i couldn't read it!! )
Thanks for the tip!
Old Dec 17, 2004 | 08:49 PM
SE01's Avatar
Yea replacing the climate control bulbs are a pain in the arss. You have to get these tiny bulbs from the dealer and take apart the whole unit. Good thing it works now.
Old Dec 17, 2004 | 09:09 PM
sergeo7's Avatar
Wait until it will stop working again. Same thing happened to me. Stoped working, I hit it, bulb worked for 3 weeks and then again stoped.
Old Dec 17, 2004 | 09:52 PM
studman's Avatar
You can also order the replacement bulbs from Dave Burnette at South Point Nissan. His number is 888-254-6060.
Old Jun 15, 2005 | 12:32 PM
S00NR1's Avatar
OU > *
Hate to bring back an old thread, but this exact thing happened to me last night. I tried the bang and hit method but no luck. So, how difficult a process is this going to be to change the bulb out on the bottom left side of my Auto Climate Control panel?
Old Jun 15, 2005 | 02:09 PM
icewake's Avatar
just order bulbs from nissan dealership. they are not expensive and it only takes about 20 minutes to fix. mine were out when i got the car. if you need help pm me and i will try to guide you through the process. all you need is a flathead screw driver, a medium sized but long phillips and a really small phillip(end needs to be really small doesn't matter about handle) hope i can help some
Old Jun 18, 2005 | 07:48 AM
S00NR1's Avatar
OU > *
Well, it turns out that I just had to hit the side of it a little harder because after a few whacks, it's back to working again.
Old Jun 18, 2005 | 08:46 AM
maseo77's Avatar
It will go out again, just like mine did.
Old Jun 18, 2005 | 08:44 PM
icewake's Avatar
Just take the unit out and tighten the bulbs, it just takes a screw driver to do so
Old Jun 19, 2005 | 02:45 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
There are a total of three bayonet-style bulbs housings with hold a small wedge bulb inside. The housing may be tightened using a flat-head screwdriver, although a tight turn by hand works equally as well.
For the problem listed originally, simply remove the CC unit and rescrew the bulbs back in. If you are feeling particularly adventurous, the wedge bulb may be replaced with an LED.
Old Jun 20, 2005 | 07:38 PM
After pounding the side of the dash to cure the bulb issue, it has worked since.
MikesChevelle
Mar 2, 2021 11:32 AM
dr3am
25
Oct 22, 2015 08:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
asianstyle
Aug 24, 2015 08:29 PM
