water got into my engine..need help
Old Apr 21, 2001 | 01:12 PM
buss95max's Avatar
it got in thru the cai..
anyway it idled really bad jumping back and forth.
i changed the oil and the oil filter..i dunno if it helped.
when im driving normal ~40mph its ok..nothing happens.
when i floor it..thats when the madness starts. it has turned off and refuse to pass 3rpm. i reset the ecu and try disconnecting the battery..
so basicly at higher rpms..is when the problems start.
anyone got any ideas?...
Old Apr 21, 2001 | 02:00 PM
Daniel B. Martin's Avatar
Mass Air Flow Sensor got drowned
You reset the Engine Control Module. It would have been better to read the stored Diagnostic Trouble Codes before doing the reset. You might have seen DTC 0102 pointing to a problem with the Mass Air Flow Sensor. This is one of the most important sensors on the car and is located just downstream of the air cleaner. If your engine ingested water it is likely that the MAFS got wet and possibly damaged. When the ECM senses a problem with the MAFS or its circuitry, it goes into Fail Safe mode and limits engine speed. This is consistent with your report of symptoms.
Old Apr 21, 2001 | 02:15 PM
buss95max's Avatar
so replacing the maf sensors would be a good idea?
Old Apr 21, 2001 | 02:33 PM
NickStam's Avatar
How the heck did u get water through the CAI. Isn't that pretty hard to do?
Old Apr 21, 2001 | 02:35 PM
Facts are better than guesses
There is only one Mass Air Flow Sensor.
I suggest you do a Diagnostic Trouble Code readout. There may be useful information still there, despite your premature reset. If you get DTC 0102 you might want to have your dealer test the MAFS. This is an expensive item and you wouldn't want to replace it unless it is really bad.
You might get some other DTCs too. Facts are better than guesses.
Old Apr 21, 2001 | 07:34 PM
mtrai760's Avatar
'Trynna' is not a word
Man that sucks!!! It rained pretty bad this morning in southern cali, guess that's how it happened to you, sucks man. I guess I'm gonna run out and by a bypass valve now! Good luck man.
Old Apr 22, 2001 | 06:07 AM
shumax's Avatar
bypass?
where can one get a bypass valve?
SHUMAX
Old Apr 22, 2001 | 08:39 AM
mtrai760's Avatar
Re: bypass?
SHUMAX
AEM makes them for the 3' piping of the PR CAI (not specificaly, but I'm sure it will work. I'm just going to shop around some websites until I find the best price, but I've seen mostly around $40 so far.
Old Apr 22, 2001 | 09:46 AM
NickStam's Avatar
Re: Re: bypass?
Group buy center has a group deal a while back. See if they still have it. I think it was for under $40
Old Apr 23, 2001 | 04:48 PM
buss95max's Avatar
problem fixed!
thanks to daniel b. martin's comments about it might being my MAF, i was able to get used MAF and replace my broken one. i know facts are better than guesses daniel, but i went out on a limb and tried just changing my MAF. and it worked!
my car idles fine, and theres no problems! i went to the dealer and was qouted $530 for a MAF. but was able to get a used MAF for 100 bucks....i saved major $$$$. once again thanks a lot daniel!
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
RWCreative
Sep 21, 2015 11:01 AM
