Can the 95/96 engine be put in the 97?
Old Apr 22, 2001 | 07:48 PM
Screaminfast's Avatar
I was wondering this because, I could possibly get a 95/96 motor from a junk yard, and send it out to have work done to it(port/polish, extrudehone, blueprint, balance, supercharger, etc.) and still have my daily driver. Also, I have heard that the 95/96 engine can make more hp because the ecu can be programmed.
Any help would be appreciated....thanks
Old Apr 22, 2001 | 07:51 PM
Justin95SE's Avatar
referring to the chip, i thought you could just switch those out.
just a non answer to a question.
Old Apr 22, 2001 | 08:17 PM
Sprint's Avatar
its the same engine... the only difference is the ECU, and exhaust restrictions.. but the engine itself is the same
Old Apr 22, 2001 | 08:29 PM
so even if they're the same it might be cheaper to get the 95 because its older right?
Old Apr 22, 2001 | 11:13 PM
Matrix's Avatar
Maybe....but i guess cost will be more dependent on the engine's condition and mileage.
Old Apr 22, 2001 | 11:48 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
there are also minor differences in the motor also. My 95 doesnt use a Map/Baro sensor and i picked up my motor/tranny and all misc parts from a 96 and it uses a Map/Baro sensor and some other minor differences i cant rmeember rite now. They are basically the same thing tho.
Old Apr 23, 2001 | 09:25 AM
obviously if i am going to have the engine rebuilt, balance and blueprinted, then the age of the engine doesn't matter.
Also, is it possible to push 350 ponies out of the max?
Old Apr 23, 2001 | 09:36 AM
Sprint's Avatar
yes but you are going to need Limited Slip to hold it to the floor
Old Apr 24, 2001 | 05:27 PM
Micah95GLE's Avatar
Be aware that in most states it is illegal to put an older engine into a newer car.
Old Apr 24, 2001 | 05:29 PM
Justin95SE's Avatar
really what law/purpose is that?
nm
Old Apr 24, 2001 | 05:37 PM
technically, the engine wouldn't be older because i'd have it rebuilt. Pretty much every working part on the engine would be new or resurfaced....
Old Apr 24, 2001 | 05:39 PM
Sonic's Avatar
Federal emmision standards. California is VERY strict about this.
Old Apr 24, 2001 | 08:18 PM
Matt93SE's Avatar
STFU n00b!
the only reason putting an older engine in your car would be illegal is because of emissions standards. putting the BLOCK of a 95-96 VQ in your car would be fine, as they'd still use pretty much the same parts otherwise.
but to put an older engine than that in there would be illegal, because you'd have to remove/disable/modify most of the emissions control equipment in order to make it work.. THAT'S what is illegal, not just changing engines.
It's all the green tape people. may they all rot in their own recycled coffins.
Old Apr 24, 2001 | 10:55 PM
But arent the 95/96 engines similar except for the ECU and some other parts? Tell me this though: Would having the 95/96 engine in my 97 cause me to fail inspection? Also, would I be better off doing the work to the engine that i in my car now? (The reason I wanted another one was so that I could be able to drive my car instead of waiting for 6 months)
MAXSE5SPD
Sep 17, 2022 04:00 AM
A32goldylocks
Sep 2, 2015 06:39 AM
maxinout93
Aug 20, 2015 02:17 AM
sc10692
Aug 9, 2015 09:37 AM
