Heat only works when RPM is up?
Old Dec 28, 2004 | 09:25 AM
proguitar04's Avatar
The heat in my 95 GLE only seems wo work when the car is at at least 1500 RPMs. Otherwise, it will blow cold air in my face. The coolant level is up. Any help would be very greatly appreciated, seeing as I'm in New England. Thanks
Old Dec 28, 2004 | 10:05 AM
laylow1988's Avatar
uhhh maybe your termostat is gone
Old Dec 28, 2004 | 10:11 AM
Jeff92se's Avatar
I'm needing a caw
Hmmm. Clogged heator core? Or maybe your water pump is going out. If the blades on the waterpump are all corroded, it won't pump water very well until you rev it higher.
Old Dec 28, 2004 | 10:44 AM
Yeah, my water pump is already leaking a little bit of antifreeze.
Old Dec 28, 2004 | 10:45 AM
2 Da Max's Avatar
uhm thats not a good sign
Old Dec 28, 2004 | 11:52 AM
HondaKiller718's Avatar
check the level of fluid in your radiator..
Old Dec 28, 2004 | 11:58 AM
Jeff92se's Avatar
I'm needing a caw
tnewbs
Aug 28, 2015 10:15 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
kenc15
Aug 5, 2015 08:29 AM
