Click noise with sharp turns
Originally Posted by Reeko98
I would say it is defently the axels too.
also i wated to know what is the code for the nptune blue color that you have dude
of which car and model did it come from?
code is BS3, but i have a custom metallic neptune blue. the stock color is more basic
i had my front ones swapped out earlier last year, guess i need to check them out?
Originally Posted by Chino
I get a clunk clunk sound coming from the rear when I make sharp right turns. However I've pushed hard left hand turns and I haven't heard a thing. Is my axle bad too?
Yeah it could be your upper strut bearing. Mine are shot and if I make an extremely tight turn it would start to 'click click click' as well, as the spring coil is trying to wind up as well and then relase.
Originally Posted by TJ_Max
regrease struts, any products or household products to use for regreaseing struts? wd 40 or something?
Check CV joints on front axle. Check front axle behind wheels to see if CV boot is torn. If it is, chances are that the grease has worn out and your CV joint needs to be replaced. Nowadays, the better thing to do is just replace the axle (left or right, depending on which is bad) to the outer CV joint/boot. Take a look behind the tires and check out the boots.
how are you guys determining its coming from the "rear" of your car, if its not coming from the the front of the car its not the strut bearing or axles, u dont have strut bearing in the back or cv axles, also use synthetic lythium grease to regrease, i used mobil 1 syn grease
I can sense that the clicking is coming from the rear of whichever turn im making...right turn =passenger rear, left turn=driver rear. I've noticed it and its starting to worry me.
put your car in park, have someone else turn the steering wheel left > right while you put your ears near the front wheel , one full turn for each side, that should get you a better idea of where the sound is coming from, if its coming from the rear its not your cv cause there is no CV in the rear, they are only used on the wheels that turn, not the back wheels. i think it is your cv but i dotn think the sound is coming from the rear cause when mine went they clicked too but they come from the 2 front axles...which are the CVs ...dahhh
also if you drive in reverse with parking brakes on the sound is louder if its your axles, jsut have your windows rolled down
pears
Sep 18, 2015 05:25 AM
lrb6805
Sep 17, 2015 04:49 PM
