Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
112k atf flush okay to do?
Old Dec 29, 2004 | 01:10 PM
thephatOne's Avatar
i just got a hand me down 2000 i30 from my dad well more like 4 months ago but the atf is slighty brown, no trace of red though, i was wondeirng if it safe to flush out the transmission fluid because its getting notchy and hesistant sometimes.
Old Dec 29, 2004 | 01:23 PM
flthere's Avatar
I got 107k miles when I got the ATF (ex)changed at Jiffy Lube. Everything is normal, but the transmission shifts are smoother than before. I am not sure what ATF the Jiffy Lube guys put it but I'll go for Mobil or Redline next time when I get it done ...
Old Dec 29, 2004 | 04:39 PM
S00NR1's Avatar
OU > *
Ya, do a flush and fill and I would highly suggest using either Mobil 1 or Amsoil synthetic ATF. You will need somewhere between 10-12 quarts to do a full flush and it is well worth the money. There will be an immediate difference in shift smoothness and your tranny will run much cooler. If you are lookin for a great price on Amsoil ATF, pm talking horse and he can get you a good deal.
Old Dec 30, 2004 | 12:12 AM
thephatOne's Avatar
im just worried the tranny might crap out if i switch out the atf at this high of miles. should i worry?
Old Dec 30, 2004 | 03:57 AM
PLUMMAXSE's Avatar
The tranny will surely crap out if you don't change it!!
Old Jan 3, 2005 | 12:34 PM
bladerunr's Avatar
I did my 94 with around 150K miles, used cheap ATF and had no problems.
Old Jan 11, 2005 | 07:31 PM
thephatOne's Avatar
okay i still havent had time to do my flush, and my transmission is really notchy and slips from time to time, am i still okay? or is a flush a waste of money and ride it till the tranny gives and replace it
Old Jan 11, 2005 | 11:33 PM
S00NR1's Avatar
OU > *
LOL no. Do the flush now considering a new tranny will cost you several times more than the flush.
Old Jan 12, 2005 | 07:12 AM
flthere's Avatar
Maybe a drain-n-fill now and a complete flush-n-fill after say 15k miles helps ?!?
Old Jan 12, 2005 | 12:04 PM
thephatOne's Avatar
okay i think ill go synthetic and ill try to do it tommorow, but with synthetic, do i need lubeguard black?
Old Jan 12, 2005 | 08:15 PM
S00NR1's Avatar
OU > *
You don't need anything with synthetic.....but if you feel like you must, Lubeguard is a decent product.
Old Jan 13, 2005 | 09:11 AM
schmatt's Avatar
I would suggest dropping the pan and cleaning that out too. Usually that is why the tranny goes when you flush it with high miles. The detergents in the new ATF wash all the crap up and run it through the tranny. It's not that hard, and you'll be amazed at how dirty it is. I think AMSOIL has a document on their website talking about this subject. They say that with all these machine flushers nowadays, no one ever drops the pan to clean out the sludge and clean the magnets off anymore. Just read the sticky on ATF flushing to find out how to do it.
I would definitely suggest switching over to AMSOIL.
Old Jan 13, 2005 | 12:11 PM
thephatOne's Avatar
yeah my mechanic is doinge everything from dropping the pan to cleaning everything, and im still contemplating using dino atf or synthetic atf...how good is atf good for 30k? and synthetic 50k or what...because id rather spend more money for 20 extra thousand miles haha
Old Jan 13, 2005 | 02:35 PM
S00NR1's Avatar
OU > *
OK, for the last time -- go with the synthetic ATF.
Old Jan 13, 2005 | 03:38 PM
schmatt's Avatar
synthetic atf not only lasts longer, but has a wider temperature range that it will operate properly over.
Old Jan 13, 2005 | 06:59 PM
thephatOne's Avatar
got it, thanks guys...i have an appointment for tuesday, so hopefully itll be all good by then! and i just switched to mobil one syn today so i guess ill go with mobil 1 syn atf.
sctludwig
Sep 1, 2022 01:32 PM
user 11122324
42
Jul 18, 2022 03:35 PM
RWCreative
Sep 21, 2015 11:01 AM
Violator
Sep 9, 2015 10:14 AM
mclasser
Aug 23, 2015 09:32 PM
