Internals of 5th gen MAFS in 2k2 MAFS, possible or no?
I could have sworn i read this on this board of somebody doing this. A brand new MAFS for my 2k2 is 480, a new one for a 2k0 or a 2k1 is 124. Is it possible to use the mesh and the wire thingy in the middle and replace it on the 2k2 MAFS?
Yeah... the housing can be reused... the MAF is almost a direct replacement... ya need an extra resistor from the 2k2 MAF though... I'll see if I can find the write-up for ya...
Thanks you!!!!
The info ya need should be in this thread:http://forums.maxima.org/showthread....t=maf+resistor
Its an IAT thermistor... to be precise...
You're welcome...
You're welcome...
You're welcome...
You're welcome...
Thanks a whole lot! So let me ask you this? The thermistor doesn't blow , its the part that the thermistor clips to that goes out? Correct?
technicly, you do not even need the resistor. you can install it will no problems, and it will work perfectly, BUT... it will make you check engine light stay on untill you do install the resistor. Just figured i would let you know in case you need to install it right away or something
The MAF in my 2K2 blew recently. I had a Berk intake on it.
I just put an entire 2K1 MAF unit in my car and it acted crazy stalling out. Then I put the stock part back, with just the sensor from the 2K1. Now the car runs smooth, only the SES light is on. Tomorrow I'll try putting that thermistor thing on and hopefully that'll make the light turn off? I'm thinking I might just glue that little screen to the end of the MAF tube too.
MAXSE5SPD
Sep 17, 2022 04:00 AM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
