install questions
Old Jan 13, 2005 | 05:43 PM
theMax's Avatar
install questions
Finally have my kit and am planning the install.
First how do you mount the solinoids? I don't see how they attach?
Next is anyone using a blowdown tube? I got one with the gen X kit?
Lastly how do I know I'm tapping into the correct fuel line for a wet kit?
I'm sure I'll have more questions before the install is done! thx
Old Jan 13, 2005 | 06:09 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Try this??????????
http://forums.maxima.org/showthread.php?t=185804
Old Jan 13, 2005 | 06:20 PM
theMax's Avatar
yep, that thread has lots of pics that don't work anymore, really needs to be cleaned up.
Old Jan 13, 2005 | 06:26 PM
SeaFoam2DMax's Avatar
Oh hi....
That is the truth, limited help from that thread when I looked to install my system in May
Old Jan 14, 2005 | 08:57 PM
TAPOUT's Avatar
You will lose
The only way to mount the solenoids is to get a bracket, and mount the solenoids from the little screw holes on the bottom of the solenoid, and then mount the whole bracket. There is no right or wrong, just looks good or looks bad. I never even mounted mine. The routing of all the nitrous lines were able to support the weight of them.
Old Jan 15, 2005 | 07:43 AM
theMax's Avatar
Thanks, I found the screws that go into the bottom of the solenoids. Nowhere in the NX instructions does it say how to attach them to the brackets. Their wiring diagrams are good but they do not do a good job at telling you how the parts fit together.
So does the FPSS go before or after the fuel solenoid?
Old Jan 15, 2005 | 09:13 PM
Bags's Avatar
fair enough, but it had plenty of working pics... what was not in there that you needed?
Old Jan 15, 2005 | 10:27 PM
theMax's Avatar
Some good closeups of how things go together. Where the lines are run and where the wires are attached.
I'll take some shots of the details as I go if someone wants to upload.
A good how to would be good with step by step instructions on how to tap in and mount everything.
Old Jan 16, 2005 | 05:57 PM
Bags's Avatar
If I had nitrous I would....
If you take the pics and email them to me, I'll host them.. they can be any size...
b a g s 1 4 2 ( a t ) yahoo
No spaces and put @ where the ( a t ) is.. and .com after yahoo.. damn spammers
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
