Installing newer VQ w/some rust and have questions
Old Jan 14, 2005 | 01:30 PM
nismology's Avatar
I picked up a newer VQ with around 50k miles on it for $400 bux. The reason they were selling it so cheap is cus the oil pan has some damage. No biggie, i'll just reuse the old one. But the spark plug cover is broken and was only covering the spark plug hole #2. Numbers 4 and 6 were exposed to the elements. They didnt even have the ignition coil in place. Those 2 spark plug holes are full of rust. Is there any chance that the combustion chamber is rusted out too. Also, the coolant tube that attaches to the upper radiator hose and goes into the block was exposed and also has rust in it. Who knows if the coolant passages in the engine have rust too. Oh man, i almost forgot about the driveplate. You guessed it, that's rusted too. Should i try to salvage this engine or would i be better off returning it and getting one with no rust issues?? Thanks in advance.
Mike
P.S. anything else i should check for??
Old Jan 14, 2005 | 01:34 PM
goodhead's Avatar
return it too much trouble, most yard have 30-90 warranties
Old Jan 14, 2005 | 03:50 PM
nismology's Avatar
You think so?? The next cheapest engine would be in the 500 range. My friend told me something that i didnt think about. The spark plugs are still in the holes. So although the holes are rusty, it would prevent water from getting into the combustion chambers. One down. As for the coolant system having rust in it, what can i do to fix that?
Old Jan 14, 2005 | 06:20 PM
Jason R's Avatar
aka UNCDooD
get your money back and buy the engine I have for sale.
Old Jan 14, 2005 | 07:15 PM
nismology's Avatar
Hmmm...thanks for the offer but shipping would own me...
Edit: Unless it's $400 shipped!!!
Old Jan 15, 2005 | 06:56 AM
nismology's Avatar
Hmmm... i just thought about the rusted driveplate and i'll just use the driveplate from the old engine. Two down. So what about the rust that's perhaps formed in the coolant passages??
Old Jan 15, 2005 | 07:57 AM
Broaner's Avatar
2060lbs and falling...
If there was any residual coolant in the passages it would prevent rusting. Most of the passages are aluminum and should not rust. The only steel is the one above the front exhaust manifold. You could always use the the parts off the old motor as you are with the other stuff. The upper rad log comes off with four 12mm bolts.
Old Jan 15, 2005 | 05:22 PM
nismology's Avatar
Nice. Thanks for the quick reply. So i guess i shouldn't be too worried huh? Anything else i should check for while the engine is out??
Old Jan 15, 2005 | 10:02 PM
Broaner's Avatar
Do all the basics. Make sure all seals are completely dry. It will be much easier to do them now. Open up the thermostat housing and make sure the unit is functional.
Old Jan 16, 2005 | 05:17 AM
Jason R's Avatar
aka UNCDooD
haha. shipping wasn't too bad when i bought it. i only paid $175 to have it shipped to me and that was from ohio.
Old Jan 16, 2005 | 07:59 AM
Broaner's Avatar
$175 to ship the whole engine?! D@mn. Shipping was $150 for my tranny.
Maximeltman
Advance Paint and Body Work
Sep 10, 2019 10:24 AM
maxinout93
Oct 27, 2015 01:29 PM
rtirbany
Sep 8, 2015 11:46 AM
stromm
Aug 27, 2015 04:13 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
