NX wet kit just ordered YAY!!! some questions....
Old Jan 15, 2005 | 02:14 PM
RI-Max's Avatar
hey i just bought the NX wet kit. from nopi . thanx for the link guys. 460 shipped
i just wanna see if i got everything i need. for a 75/100 shot.
NX kit
Gauges FP/EGT/nitrous gauge
step 2 colder plugs gapped at .040
walbro fuel pump
bottle warmer
remote bottle opener
purge kit
a few ? i have is that i know i need a bottle heater. but which ones do u guys get??? seen some on ebay for. $200+
how many of u guys have a bottle remove open?? should i get one?
the purge kit just get the moisture out of the lines right. need that 2. then. right?
any other advise??? btw i know i have high miles 180,xxx. but i don't care if i blow it. i work in a garage. so i have it kinda easy.
Old Jan 15, 2005 | 02:18 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
do you mean REMOTE BOTTLE OPENER? don't need it but if you rather hit a button to activated from the front seat vs. opening the bottle before a race and closing it after the race, you should get it........
Old Jan 15, 2005 | 04:18 PM
RI-Max's Avatar
what happens if i leave it open???
srry i'll edit that.
Old Jan 15, 2005 | 04:51 PM
Tek-Niq's Avatar
sorry I don't have nos, but all I can say is they use the purge kit for a reason and thats take out the left over nos in the lines. it might not be good though. wait till the nos members come in and answer you're questions.
I just know bout the remote bottle opener....
Old Jan 16, 2005 | 10:20 AM
Jason R's Avatar
aka UNCDooD
purge kit is to remove any and all air out of the nitrous lines. after you spray the car and close the bottle it is best to purge the lines again to remove any left over nitrous from them so that they don't freeze up.
and if you leave the bottle open there is a pretty good chance that all the nitrous will leak out of the bottle.
Old Jan 16, 2005 | 10:29 AM
SonicDust187's Avatar
NX kit
walbro fuel pump
bottle warmer
purge kit
Drop the gap to .036 for the 75 and 100 shot. Maybe sure you get the 190 high flow pump. A purge is not a must, but a heater is a must. Remote opener is for you, its not good to leave it open cause it puts a lot of pressure on the nitrous solenoid. Over time it can cause wear on it.
Old Jan 16, 2005 | 02:27 PM
RI-Max's Avatar
thanx u that was very useful info.
SonicDust187 & UNCDooD
i can run a 50 with 2step colder plugs right gapped at what??? but not with my ngk plat. stock plugs. cause copper is best. use ngk right? any part number for the step 2.
cause im gonna run a 50 first until i get the guages and fuel pump.
btw what kinda bottle heater u guys be useing??? for your NX kits???
should i get the universal purge kits from ebay???
Old Jan 16, 2005 | 03:02 PM
I use the NX heater because it measures pressure and not temp to keep the bottle properly pressurized. I would use one step colder after talkK copper plugs. BKR6E-11 Copper Spark Plugs are one step colder.
Old Jan 16, 2005 | 04:07 PM
Jason R's Avatar
aka UNCDooD
i wouldn't even touch 2 step colder plugs unless i was spraying 125+ shot.
Old Jan 16, 2005 | 04:34 PM
RI-Max's Avatar
ok thanx fellas
Old Mar 11, 2005 | 05:45 PM
Dean77's Avatar
Guys,
Check out the Dynotune Nitrous Bottle Heater. It measures pressure - but unlike the NX heater it is adjustable so you can set it to the pressure you want! Also the NX is 240 Watt - the Dynotune one is 300 Watt!
http://www.speedshop.org/store/scrip...p?idproduct=17
Dean
Old Mar 12, 2005 | 07:06 AM
Jason R's Avatar
aka UNCDooD
Originally Posted by Dean77
Guys,
Dean
very nice find. thanks for the URL.
Old Mar 12, 2005 | 09:53 AM
RI-Max's Avatar
still like my nx heater betta.
Apr 16, 2020 05:15 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
bigfrank
Oct 1, 2015 12:51 PM
Pied
Sep 26, 2015 03:29 PM
