Daniel B Martin.. need help.. check engine light
I had check engine light came up again. this time i recorded flashing. it was 05 05. so I went to check the code. it said "No Failure Recorded/Detected"
does this mean there's nothing wrong with the car? or should I still take it to mechanic?
thanks in advance..
thanks in advance..
you may have had the gas cap open or something.. reset it and see if it comes back
thanks in advance..
thanks in advance..
Is it possible you inadvertantly cleared the ECU while trying to do the readout? I always thought 0505 means "AOK" and doesn't illuminate the CEL.
Assuming the ECU is now reset, you could drive as usual. If there were a problem originally it would still be there and engage the CEL again, giving you a second chance to do the readout. The original problem, if any, probably isn't too pernicious so it's probably safe to drive your car. You would have known if the problem were bad by the aberrant behavior of your car in the first place.
thanks in advance..
thanks in advance..
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
