fog light wiring question
Old Jan 18, 2005 | 10:30 AM
guyfromkop's Avatar
i'm buying a set of fogs that have 2 different options, anyone know how i can wire these into the parking lights so they go on with the parking lights, but also have a switch to choose which option i want it on?
Old Jan 18, 2005 | 10:38 AM
Irish's Avatar
This is a democracy
check the stickies, fog light re wire should be in therer, and this is almost the same
Old Jan 18, 2005 | 10:49 AM
|Bijan|'s Avatar
UCF Lexus
Stock fog lamps?
Stock fog light switch?
Be more specific....
Old Jan 18, 2005 | 10:57 AM
guyfromkop's Avatar
aftermarket fogs with aftermarket switch, running all my own wires and not using any stock wires
Old Jan 18, 2005 | 11:00 AM
Irish's Avatar
This is a democracy
why dont you just wire them independently that way you can have en on when you want?
Old Jan 18, 2005 | 11:03 AM
guyfromkop's Avatar
because i want them to automatically come on when i turn on my parking lights
Old Jan 18, 2005 | 11:11 AM
kbmaxima's Avatar
wire them into your clearance or side light. that way when you have your parking lights on, you can either have fogs on or off. would look nicer with parking lights rather than just fogs by themselves
Old Jan 18, 2005 | 11:20 AM
guyfromkop's Avatar
but how do i wire them?
Old Jan 18, 2005 | 11:35 AM
|Bijan|'s Avatar
UCF Lexus
RED = 12v
Black = ground
Then run a wire from 12v - to signal wire of corner lamps
Old Jan 18, 2005 | 11:41 AM
guyfromkop's Avatar
where does the wire to the switch, to change between the 2 options, go?
Old Jan 19, 2005 | 12:48 PM
ThurzNite's Avatar
Mine are relayed off the corner lamp. When the parking lights are on, triggers relay to feed 12v to the aux lights. If you wanna add a switch in the cabin, be prepared to fish wire through the firewall (which I don't like doing). If this's the case, you can put the switch anywhere. I'd put the switch on a ground... don't like 12v juice running around. If you absolutely need a diagram, I will draw 1 up.
Jae
Old Jan 19, 2005 | 01:08 PM
guyfromkop's Avatar
yea but my question is that my fogs have 2 different options, driving and fogs, and there is a switch to go in between the two. but i want my fogs to turn on automatically with the parking lights, then i can choose which one i want
Old Jan 19, 2005 | 03:19 PM
kbmaxima's Avatar
Originally Posted by Soul Fly
RED = 12v
Black = ground
When you turn on your car's parking lights, you will then have to option to switch between driving/fog lights on your aftermarket foglights. red to corner lamp red, black to ground, which is anything touching the frame of the car [best ground]. there should have been instructions with yours. I bought mien for 10 bucks and had very detailed instructions
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
