Is bottle heater NEEDED for 50 shot?
Old Jan 19, 2005 | 04:43 PM
TheMax95's Avatar
I know it helps but is the heater needed to run a 50 shot safely on my 96 5speed?
Also is a no2 gauge needed or can I just mount and connect everything and expect it to perform the right way? Reason I'm asking is because I'm looking for a budget kit just to bolt on hp. No fancy switches, no gauges, nothing. Just a bottle in the trunk, solenoid under the hood and a jet into the intake pipe. Will it work?
-Paul
Old Jan 19, 2005 | 05:49 PM
SonicDust187's Avatar
Its n2o, and yes a heater is needed for every shot setting.
Old Jan 19, 2005 | 08:03 PM
Jason R's Avatar
aka UNCDooD
thats all mine really is. its just the nitrous kit and i'm running a 75 wet shot. goodies will be added a little on down the road.
Old Jan 20, 2005 | 06:50 AM
ddpack's Avatar
You're from cold country. If you have nitrous w/o a heater and spray, you might as well roll your window down and through a few buck out. Nitrous is worthless in cold weather w/o a heater.
Old Jan 20, 2005 | 11:44 AM
subs1000w's Avatar
+1 to that the only way youll get the advertised shot is with a heater and a gauge
wothout a heater youll just run really rich and in the coldest weather you will be slower while on the spray than off
in this 30degree weather my bottle sits at about 600psi which is way to low
a heater is less than 100$ and a gauge is around 30$ just get them and do it right
and try to get a heater that is controlled by a pressure switch
Old Jan 20, 2005 | 05:08 PM
TheMax95's Avatar
ok Thanks alot guys. I guess another $150 ish is worth it to have a safe n2o (not no2) setup. typo.....dumbazz.
Thanks again for the help.
-Paul
Old Jan 26, 2005 | 08:04 PM
TAPOUT's Avatar
You will lose
-Paul
It's not about being safe, it's about having enough bottle pressure for it to make a difference. Nitrous feels real good when you get the pressure up to about 1200 psi. 600 psi is nothing, 900 is ok, 1200 is .
smplyamzng
Dec 13, 2015 01:19 PM
dr3am
25
Oct 22, 2015 08:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
TonyJr
Aug 20, 2015 12:14 AM
acw
Aug 7, 2015 04:20 PM
