JWT ecu question
Old Jan 19, 2005 | 08:13 PM
SMX95's Avatar
JWT ecu question
Ok main concern is about advance timing. Is this a good thing to have in a car for daily driving? Will my engine running hotter? is it safe for summer time? I just need to know before I buy an ecu. What Are my advantages of having this ecu over stock.
-Smx95
Old Jan 19, 2005 | 08:42 PM
SMX95's Avatar
bump anyone?
Old Jan 20, 2005 | 09:28 PM
meximax's Avatar
SC Overspinning Swapper!!
Advantages: A bit more power and the extended rev limiter (works great with Variable Intake)
I can't think of single disadvantage, except for the price. I have had the JWT Ecu with Nitrous Control for well over 2 years. Not a single problem to date.
With the exception of the extended rpm, a couple of OBD-II piggy back systems can alter MAF, TPS, etc. readings and and allow you to advance timing and tailor the air/fuel mixture to a desired stoichiometric ratios. The latter requires some dyno time and/or a wide band O2 sensor to precisely measure the air/fuel mixture and tune appropriately.
Old Jan 20, 2005 | 09:29 PM
meximax's Avatar
By the way, my car is a daily driver in the hot muggy Houston summers. The knock sensor will keep your knocking in check if timing is too advanced.
Old Jan 20, 2005 | 09:33 PM
naijai's Avatar
how much power and whats else is done apart from the revlimiter
t6378tp
Sep 29, 2018 04:27 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
